#41 |
Just looking...
![]() iTrader: 1 reviews
Ok so i think i am going to settle on the hitech stage II, im going to spend the money there instead of things such as headlights. On hitechs website it says i wont need springs so i wont be doing that, the only thing i am worried about is the ptv. How close are they to hitting? I would rather not shave off any of the valves if possible
#42 |
Just looking...
bump
#43 |
1997 Mustang GT
13.56@102.94
If it were me doing a used head swap and if I were installing cams, too, I'd get some hipo valve springs like compcams have and probably check/replace the valve seals if need be.
![]() 1997 Mustang GT Aluminum Block PI swap & 4R70W to TR3550 swapped. Best 1/8: 2.04 60ft 8.74@81.85 & Best 1/4: 2.045 60ft 13.56@102.94 all on stock 245-17's My Garage |
#44 |
1996 Mustang GT Vert
+1 on the seals and springs.
Depending on the lift, you may need to get some valve spring retainers milled for more clearance to your seals, I got my cams, springs and retainer milling from hi-tech. The seals are easy to do once you have the springs off.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's |
#45 | |
![]() Casey |
#46 | |
With a stock bottom end, and no boost I have no issues running these cams without springs. My friend has actually been running them HARD now with stock springs that have 150,000miles on them. 6500rpm shift points no problem! If you were going to run boost, or push the RPM past 6500rpm I would be all for doing springs, that or if you feel the stock springs have excessive milage on them. The springs in my example above with 150k on them, I personally would have replaced, but not my car not my money. |
#47 |
04 MUSTANG GT
14.5 @ 97.2
good luck
#48 |
Just looking...
I talked to a guy at a motor part shop today and he said using the stiffer springs in this situation might even do more harm then good. If the springs arent needed they might slam the valves closed to hard and will put more stress on stuff then normal springs, he said not to go overkill,
#49 |
if you are going to do the PI swap and not do a whole PI engine I would go with the smallest cams you can for PTV clearance and stick with the stock springs
#50 |
the hitech stage II will work with your stock springs, and you wont have any piston/valve clearance issues, even with non-pi pistons.
97' GT 98' DSG Cobra |
#51 |
Just looking...
I have to wait like a month or two now
,But have you done this...or, how do you know? |
#52 |
Actually they are very close on a NPI motor. I can go into why, but trust me from personal experiance, they are very close, and PTV MUST be checked. That is why we recomend machining the margin down on the vales to gain MORE than addiquite clearance. (You can gain close to .040 clearance by doing so) we do this on all the PI swap cars since it is so easy to do when the heads are off, and we only charge $25 to do it if a customer who has purchased our cams ship us thier valves. Such as I have discussed with Drtbkr.
#53 | |
Just looking...
I will be doing this for sure. Just to be safe and make sure things go right.
Threads Similar to: PI Head Swap
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 01:57 AM |
| head swap | Mustang RacR94 | 99-04 | 9 | April 25th, 2007 06:27 PM |
| PI Head Swap | therooster | 96-98 | 6 | October 19th, 2006 12:13 PM |
| Head Swap | wikdsvt | 5.0 Mustangs | 5 | October 10th, 2006 07:19 PM |
| 5.4L Head swap??? | rwk3072 | 96-98 | 7 | July 23rd, 2006 01:40 AM |
