Just looking...
![]() iTrader: 1 reviews
PI Head Swap
I am about to a PI head swap shortly but i have a couple of questions first.
1. If i were to buy pi heads out of a 2001 Bullitt Mustang, would i need to buy new valve covers? or would the ones out of my 97 gt work? 2. How hard is the swap to do? I will be doing it on the garage floor so no lifts or anything. It doesnt look like doing the actual swap of the heads will be that bad. But i have heard that the timing can be a bitch on these mustangs? Will rep for help! THanks |
Proud American
depending on the bullitt you may need new valve covers... and the swap is easy as long as you have the patients...
what part of 2001 are the heads from??
beg thru mid 01 you will need windsor covers mid 01 thru 02 you can use your own... |
Just looking...
so the car happens to be in the crossover year. Im not sure if its early or late 2001. It was an ebay ad.
Addressing the timing thing: it's really not hard. Just follow the timing guide in the chilton's book and you'll be set. Be sure to turn the engine over a few times by hand just to be sure. I'd be sure to have a vice grip handy to compress the chain tensioners though. Those were a PITA.
#6 | |
Just looking...
Also did you run your 15.2 with the pi swap? |
Just looking...
Ok, i have a part number off of the Bullitt Pi Heads, it is
RF-1L2E-6090-D22D Would you be able to tell if they are the windsor or romeo heads from that? |
I think those are explorer heads man from like a late 01 early 02. Mine are SHM. The swap isnt too bad and you can do it in your garage. It sucks like all head changing/head gasket jobs...but the result is awesome
Full Steeda G-Trac Suspension, Stage 2 SHM PI heads, FRPP High Flow Intake, Fluidyne Radiator, HID light conversion, Cobra Brake upgrade, FR500 17x9 Anthracite, BBK cold air, SHM valvecovers, SHM bore/stroke kit. |
For the record, the 15.2 was before the PI swap, heh. I just haven't had it to the track since then. My friend's stang ran 14.4 consistently when he brought it to the track and though and I beat him when we raced.
BUy a PI motor and screw the PI swap./
Proud American
This is a good idea... only for one thing... just to have a slow car still.... i know that tenths are what edge out the competiton... and if that extra half point of compression even gives me only 3 horsepower, I am going to bump the compression up... Guess its all in how much money you want to spend too
I know I went from 15.7 npi to 13.90's PI then slapped on a S/C & gears and nailed 11.98 with 10lbs. Try getting a safe tune with a S/C, stock bottom end and anything more than 6lbs of boost with 10.6:1 compression...wont happen.
99% of all NPI engines are going to be high mileage engines and increasing cylinder pressure is just one added possibility of failure and unreliability. Why wouldn't you want to gain back some life of an engine by buying a low mileage engine and be able to upgrade later? Also Tearing into an engine doesn't seem smart to me when an engine swap could be done in a day. If I were to do this all over again, I would have done one of two things... Swapped to to a 4v and S/C'd from there OR swapped to a 4v and built one nasty high compression street car with a bottle for the track. |
#13 | |
Proud American
or just a small pushrod engine with a carb and a small 250 shot thats my plan... should get 11.50s at my atltiude...but i could do a PI head swap in less than a day if its just a head swap no degreening of cams and all that shit... and i put a NPI 27K mile motor, and guess what it ran better that all the PI n/a mustangs in my car club... closest one was a 14.89 and that was a PI engine with full bolt ons minus longtubes and cams... my NPI stock ran 14.68. guess it could be argued quite a bit... but mine also had a fresh set of head gaskets and been gone through and now has less than 450 miles on itsince june.
Guest
Posts: n/a
You are gonna love the PI swap bro and with your gears and tune it is really gonna wake up the tired NPI block.. Good luck..
Just looking...
Yea i really hope so. I just hope my bottom end dont give out. After that. Its time to boost!!
1997 Mustang GT
14.6 @ 98
What mustangs have the original PI heads? GT? Years? Help!
1997 Mustang GT, Cobra Front Bumper, Cobra R hood, , Cobra Suspension, Cobra Brakes, Cobra Steering, Cobra Emblems, Cobra 2003 Black Rims, and Blacked out tail lights, 3 Inch Exhaust w/o cats, two MAC mufflers, Custom H pipe ![]()
Just looking...
99-04 gt. Youre gonna want an 01 or newer though i think because then you wont have to buy different valve covers. Mayve someone else will chime in with exact details
Just looking...
i take it this guy was instantly banned?
Just looking...
And now the pic is gone. Thanks whichever mod took care of the guy that shit all over my thread
What did you decide to go with?
Threads Similar to: PI Head Swap
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 01:57 AM |
| head swap | Mustang RacR94 | 99-04 | 9 | April 25th, 2007 06:27 PM |
| PI Head Swap | therooster | 96-98 | 6 | October 19th, 2006 12:13 PM |
| Head Swap | wikdsvt | 5.0 Mustangs | 5 | October 10th, 2006 07:19 PM |
| 5.4L Head swap??? | rwk3072 | 96-98 | 7 | July 23rd, 2006 01:40 AM |
