2001 GT Motor In My 98 Gt
Old January 4th, 2009, 12:45 AM   #1
909mustangx2 is on a distinguished road
Hey guys wanted some advice...I have a 98 mustang gt and unfortuantley my motor gave up on me this weekend...My mechanic is going to put a 2001 mustang gt engine in it with 22,000 miles on it...Is this a good swap? Should i feel and get more hp with this motor seeing that it is a pi motor?
Thanks!!
He's charging me 1500 for everything...Said he's going to use everything from the intake manifold up from my 98 gt motor and put it on the 2001 motor...Is this a good price?
Old January 4th, 2009, 12:54 AM   #2
jasons_98gt's Avatar
1998 mustang GT
jasons_98gt is on a distinguished road
Send a message via Yahoo to jasons_98gt
well unless you have a pi manifold on your car now the manifold wont work because of the different port designs the non pi motors have teardrop port and the pi heads have a square port but other than that everything else will work and welcome to the forums
Old January 4th, 2009, 01:43 AM   #3
so he will have to use the intake manifold from the 2001 motor because the 98 intake manifold wont fit?
Will i feel the power increase with the 2001 motor in my 98 body?
Old January 4th, 2009, 01:45 AM   #4
Smelly Fists, Socking Cocks
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
npi won't fit unless he uses special plates or rtv to seal the leaks in the ports..... and if he does manage all that, ur going to pretty much rob urself of up to 20rwhp...
u want the whole motor, including the intake manifold. if he can't supply one, buy one
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old January 4th, 2009, 01:51 AM   #5
1998 mustang GT
Old January 4th, 2009, 02:07 AM   #6
i trust my mechanic so im pretty sure hes going to use the manifold from the 2001 but if for some reason he tried to get cheap...how would i be able to tell if he used the 98 manifold on the 2001 motor? Also will i feel a big difference in power with the 2001 motor instead of the 98 motor?
Old January 4th, 2009, 02:11 AM   #7
1998 mustang GT
you will feel a power difference yes i put pi heads and intake on my motor and it made a hell of a change
Old January 4th, 2009, 02:27 AM   #8
zippeewannabee
ZoomZoomMFer's Avatar
06' Mazda Speed6
ZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura about
iTrader: 17 reviews
Send a message via AIM to ZoomZoomMFer
yes it will... take a look at the intake...
the pi intake is a hell of alot deeper than the npi intake..
Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount
Old January 4th, 2009, 10:09 AM   #9
2002BLGT is on a distinguished road
Send a message via AIM to 2002BLGT Send a message via Yahoo to 2002BLGT
it will probably leak coolant unless he uses alot of silicone LOL .....he will need to use the 2001 intake and drill and tap a hole for the extra coolant sensor your 98 has that the 2001 intake doesnt have a hole for by the thermostat housing
Old January 4th, 2009, 04:48 PM   #10
Thanks guys for the info...i just was making sure i know what to look for when i pick up the car...i got to go down to the shop tommorow anyways so i will make sure i know that he does everything the right way...
Is 1500 a good price for the swap...the 2001 motor has 20,000 miles on it....He was going to put another 98 engine in there but i told him thats a waist, might as well get a pi motor!!
Old January 4th, 2009, 04:56 PM   #11
sxynerd's Avatar
sxynerd is on a distinguished road
I picked up 60hp.
Old January 4th, 2009, 07:40 PM   #12
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
1500 for the swap is a helluva deal, if thats including labor.. especially for low mileage, and its already PI.. just make sure he uses, the pi intake..
You will love the new engine.
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
Old January 5th, 2009, 03:34 AM   #13
1998 mustang gt vert
98stanger is on a distinguished road
Send a message via AIM to 98stanger Send a message via Yahoo to 98stanger
i paid 2000 for my 03 motor with 43000 miles and another 1000 to get everything installed. he was wanting 1400 but i gave him my 98 block so he knocked 400 off. to me that sounds hella awesome. just make sure when u get parts from now on to get them for the 01 and u have to make sure u know which 01 motor u have. thats when they swapped a few things on it and i know the water pump for sure is diffrent
check out my garage for info
Threads Similar to: 2001 GT Motor In My 98 Gt
2001 s281 hood for 2001 gt? GTSilverBullit 99-04 2 October 14th, 2008 12:43 AM
How much boost can you put on a stock 4.6 v8 motor with out mesing up your motor? Jonathan General Tech 3 January 2nd, 2008 10:34 PM
