PI intake w/o crossover
Old January 7th, 2009, 01:02 AM   #1
ssprofession's Avatar
ssprofession is on a distinguished road
I got a PI intake from a friend that came off his 2000 Mustang GT and was going to use it to do the NPI to PI intake swap but the intake I got does not have the aluminum crossover on it. Will this matter for the install or not. Will post a pic shortly.
Intake is going on a 98 Mustang GT the NPI intake I have on there now has the aluminum crossover
2003 GT vert
4.10's
Sniper Tune
CAI, 75mm TB, Typhoon Intake
Bassani O/R x pipe and flows.
1998 GT coupe
4.10's
Sniper Tune
PI Intake swap
Old January 7th, 2009, 01:36 AM   #2
NMR-2vGT's Avatar
1996 GT
Too Slow....
NMR-2vGT will become famous soon enough
Send a message via AIM to NMR-2vGT Send a message via MSN to NMR-2vGT
You can switch the crossovers and use the one off of the npi intake
1996 Mustang GT, Full PI Swap, MGW Shifter, Magnaflow Cat-back, K&N Filter
MM Unite For Bubba
Old January 7th, 2009, 01:58 AM   #3
I looked at doing that but the PI intake I have is made all together. There is no way of swapping the crossovers.
2003 GT vert
4.10's
Sniper Tune
1998 GT coupe
4.10's
Sniper Tune
PI Intake swap
Old January 7th, 2009, 03:54 AM   #4
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
If the PI intake has a plastic crossover, your screwed.
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
Old January 7th, 2009, 04:10 AM   #5
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
^you will be fine for a while but the plastic cross over always splits, thats why they came with the aluminum cross over. Try looking for a 01-04 PI intake at a junk yard.
Old January 7th, 2009, 04:21 AM   #6
Smelly Fists, Socking Cocks
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
no he won't because u can't drill and tap for the second coolant sensor....
he'll have a constant CEL and his AC won't work
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old January 7th, 2009, 04:32 AM   #7
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
The 2000 gt and the 2001-04 gt intake is the same except for the aluminum coolant runner.
Old January 7th, 2009, 04:38 AM   #8
G.T. Rags's Avatar
Millenium Falcon
correct, but a lot of good a plastic crossover will do him when he needs to drill and tap it for a second coolant sensor because he's putting it on a 98
Old January 7th, 2009, 06:15 AM   #9
I've did some research and everyone says the 99-00 intakes are pretty much garbage due to them cracking so I figured I will just invest in the intake with the aluminum crossover since I would prolly have to replace it later on anyways.
2003 GT vert
4.10's
Sniper Tune
1998 GT coupe
4.10's
Sniper Tune
PI Intake swap
Old January 7th, 2009, 06:17 AM   #10
also if I get a 01-04 intake can I swap the aluminum piece from my NPI intake to the PI intake so I wont have to tap it out?
2003 GT vert
4.10's
Sniper Tune
1998 GT coupe
4.10's
Sniper Tune
PI Intake swap
Old January 7th, 2009, 02:20 PM   #11
NMR-2vGT's Avatar
1996 GT
Too Slow....
Yes, thats what i did
MM Unite For Bubba
Old January 7th, 2009, 02:22 PM   #12
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
Yah, if they both are aluminum crossovers, then its just four bolts.. and then you won't have to tap it..
If you have a plastic crossover, you are out of luck. So buy a PI Intake with a aluminum crossover, swap em out, and your set.
Cammed 2v
Old January 8th, 2009, 04:23 PM   #13
1997 Mustang GT
not as slow... PI swapped :-)
mustangracer2g is on a distinguished road
wait the crossovers are interchangeable? i did not know that... im such a noob.. damn im def gonna do that so i dont have to worry about tapping a hole, thanks! sweet.. and yeah the non alum crossover intakes blow out all the time.. it sucks.. gluck with ur swap man
If there's one thing in life you should never take for granted its the ability to drive fast when given the hp to. (PI engine swapped now, so i can go just a lil bit faster haha)
oh yeah, and why the hell do imports always try to race me?!
Old January 8th, 2009, 04:40 PM   #14
2009 ROTY
AzSonicSnake's Avatar
2003 SVT Cobra
11.07@127
AzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud of
Send a message via AIM to AzSonicSnake Send a message via MSN to AzSonicSnake
definetly would not waste time with a plastic crossover after having the plastic one on my 98 gt spring a leak...
MM Cobra Club #25 My Autolog Profile
Threads Similar to: PI intake w/o crossover
water crossover on intake manifold leaking coolant hardhitter 99-04 10 January 5th, 2009 03:39 AM
crossover question Mustang RacR94 5.0 Mustangs 2 August 19th, 2008 10:13 AM
crossover pipe laserstang2 General Tech 4 February 19th, 2007 03:59 AM
straights with a crossover? GotBoost232 V6 Mustangs 11 February 6th, 2007 08:42 PM
Crossover pipe GreenFaleen V6 Mustangs 5 December 1st, 2006 08:18 PM
