knocking sound
Old January 19th, 2009, 10:13 PM   #1
1998 Mustang GT
Gt98 is on a distinguished road
knocking sound
Hey guys sometimes when i take a right turn at around 15mph i hear the knocking sound from my left hand side. I can't figure what it is please help??
Old January 19th, 2009, 10:17 PM   #2
ajm
Is the noise continous or kinda like one big thud/bump/knock?
Old January 20th, 2009, 04:30 AM   #3
1997 Mustang GT
not as slow... PI swapped :-)
mustangracer2g is on a distinguished road
are you breaking when turning? and yeah what ^ said
If there's one thing in life you should never take for granted its the ability to drive fast when given the hp to. (PI engine swapped now, so i can go just a lil bit faster haha)
oh yeah, and why the hell do imports always try to race me?!
Old January 20th, 2009, 03:37 PM   #4
1998 Mustang GT
its continous and i usually don;t break. its a knocking sound that continues all through the turn until i exit. Maybe a rear axle?
Old January 20th, 2009, 03:46 PM   #5
ajm
Easiest way to determine between the front and rear would probably be to have someone ride with you in the back seat and listen. Then go from there to figure out the problem.
Old January 20th, 2009, 03:46 PM   #6
jasons_98gt's Avatar
1998 mustang GT
jasons_98gt is on a distinguished road
Send a message via Yahoo to jasons_98gt
check your wheel bearings tie rods balljoints? i had a similar problem with a clunking sound sounded like axel noise even had shops tell me it was the rear end dumbasses i had a bad balljoint and wheel bearing on the front passenger side
Old January 20th, 2009, 08:25 PM   #7
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all
iTrader: 13 reviews
ball joint or rear axle bearing would be my guess. Are you getting any grease or an unusual amount of black residue on your rear wheel?
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old January 24th, 2009, 05:40 AM   #8
1998 Mustang GT
No i'm getting no excess grease or any type of gunk for that matter i'm stumped and i don't want to drop money into it and its still not fixed lol
Old January 24th, 2009, 11:23 AM   #9
1996 mustang gt
unkown
jchr96gt is on a distinguished road
prolly a broken bearing or something..
Old January 24th, 2009, 12:20 PM   #10
Proud American
MustangMatt96GT's Avatar
Sounds like a balljoint to me.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old January 25th, 2009, 07:36 PM   #11
1998 Mustang GT
dang is a ball joint hard to replace and any guidance would be appreciated lol thank a bunch
Old January 25th, 2009, 07:45 PM   #12
Got Ford's Avatar
2001 F-150
Got Ford will become famous soon enoughGot Ford will become famous soon enough
Send a message via AIM to Got Ford
is the car lowered at all? could be the tire rubbing the wheel well, or a ball joint like they said
Silver Vehicle Club Member #2
MM Truck Crew Member #2
MODS LIST: Synthetic blinker fluid, Stg2 muffler bearings(cryo treated), Upgraded bumper bolts, computer reflashIII, 92hp shot of nitrous into the transmission(faster shifting and makes it 24/7 shifting fukkers!), Titanum locking oil drain plug(weight reduction), Spongebob harness(gotta be safe), Oil cooled air intake with a built in turbo simulator blow off valve, and a custom CANOOTER valve!
Old January 26th, 2009, 04:12 PM   #13
1996 mustang gt
unkown
its prolly th ball joint
its hard to change them because you have to remove alot just to get to them.but you should change it soon before your axle and alignement screw up
Old January 26th, 2009, 05:08 PM   #14
1998 Mustang GT
no its not riding lower. Thanks guys for all your input i'm going to get it fixed this weekeend
Threads Similar to: knocking sound
knocking sound Genevieve! 99-04 32 June 10th, 2008 08:21 AM
Knocking sound. I doubt it's detonation. Muscletang 96-98 5 May 22nd, 2008 12:34 PM
Sound issue, (sound clip coming later) dgt_mustang V6 Mustangs 5 April 11th, 2008 06:08 PM
knocking or not knocking? jacutis V6 Mustangs 12 January 14th, 2008 11:17 PM
Knocking Sound Maximus General Tech 10 July 20th, 2007 08:48 PM
