#21 |
1997 Mustang GT
who should i look into as far as the gears are concerned? i found a ring & pinion set from ford racing for $180. is that good or should i shop around for different brands?
#22 |
Ford Racing gears aren't bad. There's lots of different brands out there. Keep in mind thats its several hundred dollars to install at most shops.
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
#23 |
Genibus Nitito Canus
Ford Racing is considered good around here as far as gears go. DIY FTW
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, SLP Loudmouth ![]() |
#24 |
1997 Mustang GT
OK, cool. I know how to install gears, so I can keep the costs relatively low. Thanks a million guys.
#25 |
1998 Mustang GT
just throw some cams in it and you'll be fine!
#26 |
1996 mustang gt
unkown
4.10's the way to go
then get a full exhaust intake exc.. |
#27 |
2004 Mustang Mach 1
1994 Dodge Ram 5.9L 4WD 1976 Monte Carlo
![]() Military Crew MM Sapper Squad Zombie Killing Club Member #4 Black Stang Crew Member #5 |
#28 |
n/a
i am also new to the site, i am looking at doing performance upgrades to my '00 gt conv. right now i have a couple boltons, bbk air intake, throttle body, short shifter, stage 3 zoom clutch, ceramic brake pads, wheel spacers, catback loudmouth exhaust, and performance lowering springs. i have been getting the vibe that my next step should be a tuner and gears. i am just wondering on a scal from 1 to 10 how hard you would rate the intallation of the gears. i do all of my work myself in my garage and i have a lot of tools, but i am still worried i would screw up the rear end if i did the gearing.
P.S. i have already had to take one axle out due to a seazed up stud so i am somewhat familiar with the rearend. thanks again |
#29 |
n/a
#30 |
at far as i know, in stangs 99+ u have to use the tuner to adjust the speedo. as for installing ur own gears, personally I wouldnt do it since i dont have the proper measuring stuff, (if ur wondering what that stuff is, just youtube xtreme 4x4 from SpikeTv, they do gear installs on almost every episode). but if you have/can borrow that stuff, go for it.
#31 |
n/a
thanks
i need a 99-04 tan leather driving seat! and tuner! |
#32 |
Traction...?
1996 GT/ 2008 GT Vert
70mm throttle body with a half inch spacer. Headers are not the most easy job. But are well worth it. Get some 3:73's. Maybe some under drive pulleys.
#33 |
POWA! 24/7 fukkers
1 @ 1
jesus old thread is old.
#34 |
=worthless unless ur using a NX spacer with nitrous spray bar built in
#35 |
13.64@101mph
Honestly BEFORE you do any of that. You need to decide what you want out of the car first and foremost. Don't spend a dime before you know that because you could just be wasting your time and money. Is it going to be a drag car, autocross, full street car, street/strip car, street/autocross car etc etc. All three of those require COMPLETELY different type of parts. So let us know that decision before we can actually start to help. I'd say gears are probably the only thing that could be universal lol, unless your the type that all you do is jump on the highway and cruise 500 miles for fun then go home in that case i have a set of stock fox 2.73 gears if you want em! Lol but in all seriousness! Make that decision then go from there.
#36 | |
#37 |
N/A
I'd go for brake and suspension upgrades. If you have a V8, it should be plenty of power stock. I have strut tower supports, I'm getting lowering coils, and I'm going to get sway bar kit and shocks soon. I also advise brake upgrades because if I'm going at a good speed and start hitting my brakes, they heat up and it gets hard to brake.
If parts ain't flyin', You ain't tryin'. |
Threads Similar to: basic upgrades
| need some basic information | 03SuperchargedGT | 99-04 | 20 | July 12th, 2008 12:06 AM |
| basic maintenance | Toph6888 | V6 Mustangs | 9 | February 26th, 2008 03:36 PM |
| Basic | MSO | The Clubhouse | 17 | January 8th, 2008 04:12 PM |
| Basic help needed. | hooligan | 2.3 Mustangs | 10 | November 2nd, 2007 04:24 PM |
| Basic Information..... | FunNquick | 5.0 Mustangs | 2 | August 17th, 2006 10:08 AM |
