#21 |
Rollin' 18/ pushin' 2
Damn man, That is perplexing!!!!! Have you tried cleaning the electrical connectors to your coil packs?
#22 |
is a matter of fact i did that as well i bought some good electrical cleaner and did the coil harnesses as well as unbolted the grounds on both sides and cleaned them up with some sandpaper then i cleaned the connectors to about basically every sensor i take care of her and this is the thanks i get!
must be truth to the old saying if it has tits or wheels it will give you problems |
#23 |
be careful your car looks alot like mine, did the same thing as mine, and i was like Yay 100,000 miles and it hasnt blown up. 3 days later sparkplug dents my hood. howdafux? idk. compression went crazy and blew the threads right outa the head Dented the friggin hood. Yay Cylinder #3 FTW
#24 |
damn sorry to hear.....im cool with the compression i did a compression test im going to have it hooked up to a scanner im sure its something dumb
#25 |
are the plug wires new?
what I think might be a problem is carbon inside the plug boot
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
#26 |
KB'd GT
I would suspect a vacuum leak, but solving a problem with no data is like throwing darts in the dark. If you can hook up a vacuum gauge you could rule that out and go from there.
#27 |
Maybe it's time to pay a pro to do a diagnosis?
#28 |
1997 Mustang GT
Approx 380rwhp
![]() iTrader: 1 reviews
Thats what i'm thinking... Sounds like you've done everything else man! This sucks wish i could be of some help...
97 GT tore down and in the works! |
#29 |
eh hell thanks appreciate the help anyways guys i did check for vac leaks and found nothing there but yea im going to have a guy that used to do mechanical work for me run a diagnostics this guy knows his shit if theres anyone i can trust its him......i told him about my egr valve rattling and he said the dpfe sensor might be going bad but he can crack the problem hopfully
#30 |
i also bought a set of injectors off of ebay for 60 bucks saturday guy claims theres 60k on them but im gonna have that guy put em on his machine and clean them so i will have a decent set of fi's
#31 |
![]() ![]() ![]() ![]() was supposed to take the car today to have it diagnose now the fucker wont start![]() ![]() im so pissed i just drove the damn thing last night it ran good other than used alot of gas and have a rough idle...got in today to start it it started started shaking real bad stalled NOW THE MOTHER EFFIN THING WONT START JUST CRANKS![]() ![]() ![]() ![]() ![]()
#32 |
1998 GT Mustang
N/A
try unpluging ur IAC and adjust ur idle screw to make up the diff. and see if it idles any better
#33 |
i put a new iac valve in it the other day and i didnt make any difference
#34 |
rechecked my fuel pressure and put a new filter on it the same day as the new iac valve and i checked the fuel pressure today with key on and its getting 42lbs at the fuel rail getting spark from the coils
#35 |
went out today and the car started right up but the think is barely running it sounds so bad the motor is damn near rocking side to side its shaking so bad idle is idling up and down up and down tried disconnecting a few sensors maf iac tps etc didnt work pulled the plug wires one at a time its aching bright blue sparks fuel pressure is holding no check engine light cant find any vac leaks looked for something disconnected nothing found man am i fucking stumped
#36 |
back in business that fucker is to smart that i took my car to i had a bad coolant temp sensor it wasn't in the right ohm range i guess thats why it wasnt setting a cel light and he also replaced my cam sensor same problem the ohm's were below spec no more surging or rough idle
its a good day and he only charged me the price of the sensors and 20 bux for the diagnostics ford parts to woohoo
#37 |
1996 GT Convertible
13.88@100.71
![]() Mods: Katzkin Leather, MMR stage II heads w/PI cams, PI intake, Accufab 75mm TB & Plenum, CAI, Ram HDX clutch, Pacesetter LT's & X pipe, Pypes hi-flo cats, Flowmaster cat back,3.73 gears, Sct SF3 tuner, Mamba M2's |
#38 | |
1997 Mustang GT
13.56@102.94
At least sniff the oil through the filler neck and if it smells like gas then change it.
![]() 1997 Mustang GT Aluminum Block PI swap & 4R70W to TR3550 swapped. Best 1/8: 2.04 60ft 8.74@81.85 & Best 1/4: 2.045 60ft 13.56@102.94 all on stock 245-17's My Garage |
#39 |
2 steps ahead of ya i changed it once i got the car back
#40 |
04 MUSTANG GT
14.5 @ 97.2
hope you get it fixed i am not to good a dionostics
Threads Similar to: son of a bitch its back
| Son of a ... | 1FastFox | The Clubhouse | 9 | September 15th, 2008 03:41 PM |
| Son Of A Bi**h!!!!! | silverstang | 2005 - 2010 | 30 | September 10th, 2008 04:48 PM |
| Son of a bitch | Drick | The Clubhouse | 25 | April 18th, 2008 03:35 AM |
| SON OF A B***H | Hourofpain | The Clubhouse | 51 | October 23rd, 2007 01:23 AM |
| son of a bitch.. | HMUSN | The Clubhouse | 370 | September 10th, 2007 08:44 PM |
