son of a bitch its back
Old January 30th, 2009, 06:43 PM   #1
jasons_98gt's Avatar
1998 mustang GT
jasons_98gt is on a distinguished road
Send a message via Yahoo to jasons_98gt
sob its back
damn miss is back or whatever it is i started the car to let it warm up and i was inside the house it sounds like shiiiiittttttt exuast is purging up and down i dont know i checked the plugs fine! checked the compression fine! checked fuel pressure fine! no check engine light someone help this is getting to be on my last nerve
Old January 30th, 2009, 06:47 PM   #2
Trick Tuners's Avatar
KB'd GT
do you have any friends with a datalogger?
Old January 30th, 2009, 06:54 PM   #3
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
You checked your plug wires. If any of them or our coil are burned out or messed up, you could be getting a no-fire. The spark plug wire being messed up would result in a grounding of the spark hence the no fire. and if the plugs are going shitty enough, the miss fire will only happen when the spark gets ramped up enough with rpms.
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old January 30th, 2009, 06:55 PM   #4
Smelly Fists, Socking Cocks
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
edit ur tittle before a mod see's it
no cussing
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old January 30th, 2009, 07:02 PM   #5
1998 mustang GT
well all the plugs are firing clean the wires are only like 2 months old and the ignition coils are 2 months old as well nobody i know of with a data logger
Old January 30th, 2009, 07:10 PM   #6
1997 Mustang GT
Faster than an s4
Id still check the wires. If they are not in correctly, or are getting burned up, they could be miss firing.
The coil sounds like it wouldn't be the issue. can you tell if its miss firing, not firing, spark but no gas, or anything?
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
04' PI Motor
Old January 31st, 2009, 12:27 AM   #7
1998 mustang GT
its really hard to say honestly when it idles you can hear it mostly through the exhaust it has the purr to it then it sounds exactly like it would if someone coughed...then it starts purring again then it starts coughing and you can hear it up in the engine compartment as well....If im driving then come to a stop the idle starts jumping and the exhaust really breaks up then when i pull out sometimes i hit an occasional dead spot but on the highway it runs like a raped ape. It has tons of power pulls hills great. Just breaking up at idle
Old January 31st, 2009, 12:29 AM   #8
330CubeGt's Avatar
1994 Mustang 5.0
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
IAC Mabye?
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old January 31st, 2009, 12:53 AM   #9
1998 mustang GT
cleaned it it was still pretty shiny from the last time i cleaned it i also clean the egr valve and took the tb off and wiped the insides of that out as well
Old January 31st, 2009, 12:55 AM   #10
1998 mustang GT
i also bough a can of mass air flow cleaner and sprayed that as well didnt help either im wondering if i have a bad fuel injector the problem is that i never had a car reliable as this one and all of the sensors have 162k
Old January 31st, 2009, 01:02 AM   #11
Moderator
casper gt's Avatar
2010 mustang gt auto
casper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud of
cleaning iac/egr's doesnt work very well (not egr they dont work at idle, just thought I'd throw that in there) buy a new iac from ford (not parts store brand they are junk) if suspect.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2010 GT auto
Old January 31st, 2009, 01:24 AM   #12
1998 mustang GT
ok thanks im going to have to do more investigating i just hate to spend bux and replace to much shit and it not work
Old January 31st, 2009, 01:43 AM   #13
1998 mustang GT
think im going to pick up a new iac valve and a tps sensor
Old January 31st, 2009, 01:47 AM   #14
Moderator
casper gt's Avatar
its not likely the tps. more likely the 160 themostat these cars dont like them at all ( tried one & mine not only ran like shit it cost me 2 tenths changed back between rounds & got the 2 back & never looked back)
2010 GT auto
Old January 31st, 2009, 01:49 AM   #15
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Yeah just start w/ the IAC first
Old January 31st, 2009, 02:01 AM   #16
1998 mustang GT
Oh my 160 has been out since october i been running my 195
Old January 31st, 2009, 02:06 AM   #17
Moderator
casper gt's Avatar
oh ok just though I'd throw that in there. I only run my car when the tracks open ( is it April yet?? ) but I've been using a 180 since that 160 episode with no problems.
2010 GT auto
Old January 31st, 2009, 01:20 PM   #18
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all
iTrader: 13 reviews
Might sound retarded, but have you changed your fuel filter? Or cleaned your air filter?
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old January 31st, 2009, 02:38 PM   #19
1998 mustang GT
just cleaned my air filter last week and i put a new fuel filter on back in september
Old January 31st, 2009, 02:42 PM   #20
1998 mustang GT
i also put in a new pcv valve and ran some lucas injector clean my past few fill ups and didnt notice any change and unbolted the coil packs and cleaned them with a damp cloth to make sure they wasnt leaking at night
Threads Similar to: son of a bitch its back
Son of a ... 1FastFox The Clubhouse 9 September 15th, 2008 03:41 PM
Son Of A Bi**h!!!!! silverstang 2005 - 2010 30 September 10th, 2008 04:48 PM
Son of a bitch Drick The Clubhouse 25 April 18th, 2008 03:35 AM
SON OF A B***H Hourofpain The Clubhouse 51 October 23rd, 2007 01:23 AM
son of a bitch.. HMUSN The Clubhouse 370 September 10th, 2007 08:44 PM
