Fuel Injector sizes without regulators or fuel pumps
Old January 23rd, 2006, 12:42 AM   #1
streetstang06 is on a distinguished road
I want to get bigger injectors for my 1998 gt but don't want to have to purchase a fuel pump or regulator. What is the biggest size i can get without having to buy all that?
Old January 23rd, 2006, 12:54 AM   #2
mdvaldosta's Avatar
11.47@120.58
Probably 24's, those will be OK for sure. #30's would likely be too much. But, why are you asking? Do know that larger injectors do not increase horsepower, rather they support more. It's not likely that you will make enough horsepower without a poweradder to need more than 24's.
Old January 23rd, 2006, 01:19 AM   #3
Bill is on a distinguished road
i hear the #19's are good to 300 HP
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!!
Old January 23rd, 2006, 08:12 AM   #4
Roadhawg is on a distinguished road
Unless your engine is supercharged.......
I'm using 42lb injectors, gives me room to grow.
2003 Mustang Mach1
1995 Thunderbird LX 4.6L;
1995 Mustang 4.2L; Eaton MPX Supercharger, 11.61 @ 118mph
Old January 23rd, 2006, 03:30 PM   #5
Thats just it! I'm over 300 horsepower already and need more fuel to put into the large amount of airflow. Fuel injectors obviously do help increase horsepower or everyone would stick with the stock 19#'s. Other than the guy that says fuel injectors don't help can anyone one else tell me if i would be better off getting a fuel regulator and fuel pump with bigger injectors or should i just go for some 24#? Thanks
Old January 23rd, 2006, 04:16 PM   #6
87vert is on a distinguished road
Send a message via AIM to 87vert
what was the air fuel on the dyno? how about duty cycle? that will tell you if you need bigger injectors, and injectors do not increase horsepower they can actually decrease it if not tuned for them, a regulator would be cheaper and easier, all you have to do is up the fp and you can get more fuel.
'96 Exploder XLT 5.0 AWD
"turbos coming soon"
Old January 23rd, 2006, 06:09 PM   #7
What exactly does the fuel regulator do that the fuel pump doesn't? I'm planning on getting 24# injectors and was told just to go with a 155 lph fuel pump. Is it better to keep the stock fuel pump and get a regulator?
Old January 23rd, 2006, 06:36 PM   #8
regulator controls pressure, pump controls volume, its a good idea to upgrade everything if you plan on getting more power, dont forget a calibrated maf
Old January 23rd, 2006, 09:14 PM   #9
Does anyone know how hard it is to install a fuel pump and fuel regulator and how much time? I like to do most of the work myself. Are you saying that i should go for both the regulator and the fuel pump? Do you just choose a spot for the regulator to go or is there a certain spot? Thanks in advance!
Old January 23rd, 2006, 09:40 PM   #10
mdvaldosta's Avatar
11.47@120.58
The fuel pump is fairly straightfoward, here is an article on our site written by one of our members. It's an install in a late model Saleen, but it's gonna be nearly identical to what you'd have to do:
Saleen fuel tank swap
Just to give you an idea. You'd simply be dropping the tank and replacing the pump. The fuel pressure regulator is simple, it's right on your fuel rail under your hood. It's essential for dialing in the correct fuel pressure for a proper tune. Your stock fuel pressure regulator isn't adjustable, so you just replace it with an adjustable unit.
If your making 300hp, it's a good time to go to 24's. You won't need anymore than that unless you go with a poweradder in the future. Like already suggestion, you need a mass air meter calibrated for larger injectors, so be sure to get that too.
Old January 25th, 2006, 03:32 PM   #11
Thanks for all that info! I also have a question about the MAF now. How do you recalibrate the MAF for the 24# injectors? Or do i just need a new one?
Old January 25th, 2006, 08:17 PM   #12
mdvaldosta's Avatar
11.47@120.58
You won't be able to calibrate it yourself, you will need to buy an aftermarket unit. You may be able to get a \ tune to correct for the injector change, but it's best just to get the right MAF.
Old January 27th, 2006, 02:28 AM   #13
Hotrodvdog is on a distinguished road
Fuel pump swap is not hard. Relieve fuel pressure, undo fuel pump fuse, turn on ignition twice but don't start engine, disconnect battery, take gas cap off, undo 3 bolts that hold filler neck in gas cap compartment, support tank with car jack, undo straps(2 bolts), undo power cable, lower tank slowly, undo bolts to tank assembly, pull out fuel pump basket, take top off by pressing tabs on side of basket, lift up basket assembly, replace pump, everything else in reverse to reassemble. If you're upgrading to a Walboro, you will need to remove some material from the top of the assembly where it meets the fuel pump. I used a Dremel with a cut off wheel and it fit nicely. Very clean install. I installed a Walboro gss341. And many people said it wouldn't work. Vortech engineering carries this pump for 98-04 Mustang GTs.
Old February 26th, 2006, 08:16 PM   #14
beheivjer's Avatar
beheivjer is on a distinguished road
i was going to use #24 and a cobra maf but i could not get any answers if the cobra maf is 24 like i think it is.
1969 Early Bronco 3.5" lift 37" swampers
1969 Early Bronco 2" lift half cab
1979 2.3t Cobra
1997 Black Cobra
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Old February 26th, 2006, 08:47 PM   #15
mdvaldosta's Avatar
11.47@120.58
Yes, Cobra MAF and injectors are 24# from 93 up to 02 (well, until the 03 Cobra that is).
Old February 26th, 2006, 11:02 PM   #16
beheivjer's Avatar
you think that #24 and a cobra maf would work ok on my 98 gt?
1979 2.3t Cobra
1997 Black Cobra
Threads Similar to: Fuel Injector sizes without regulators or fuel pumps
Lucas fuel injector cleaner and fuel filter Saleen0101 Modular Mustangs 0 September 25th, 2007 04:09 PM
Fuel Pumps MustangMatt96GT Modular Mustangs 2 May 14th, 2007 01:54 PM
adjustble Fuel pressure Regulators.... fastford3388 5.0 Mustangs 7 March 17th, 2007 12:34 AM
fuel pumps CyberPrey V6 Mustangs 1 November 28th, 2006 07:26 PM
Fuel pumps Bill 5.0 Mustangs 5 December 18th, 2005 11:21 PM
