Auto To 5 Speed Swap. HELP!!!!
I currently own a 1997 Mustang GT, and I absolutely love it. However, since it was given to me as a gift, I had to take everything as it was, including the fact that it's an automatic
So I want to switch it to a 5 Speed T45 Transmission. However, I'm not sure how to go about it, for it's not enough to get the job done. Along with getting the T45, I need the clutch cables, new clutch, new flywheel, new clutch and brake pedals (Not sure about the brake pedals) and all the other parts to put it in. I'm assuming too that the car's computer system will have to be edited as well.Does anyone have any idea of what I should do or how to do this so I can successfully have a manual Mustang? (I Don't Want To Buy A New One, So Please Don't Give Me That As An Answer!) |
1998 GT Mustang
N/A
wats wrong with the auto? with some gears and shift kit u will out run manuals all day long
It's not that there's anything wrong with an Auto, I just want a Manual.
Justin B. Yost |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
i will see if i can get a write up done on this. me and doc did a manual swap on his mach and we had just about every step by step pic.
sweet2kstang if you get that up i will love you for eternity.
97' GT 98' DSG Cobra |
mm's nitrous mod
2000 mustang gt
i will have to do a little searching for the speedo set up, i dont know if the auto's cable will work for the manual and the gear.
any informantion on it would be outstanding. people ask about it alot, including myself.
If you can post that on this forum, that would be amazing. I'm assuming all the parts would be the same, despite that yours was a Mach 1?
Justin B. Yost |
I would really appreciate your help =)
Justin B. Yost |
the tranny would be a 3650, but it would be incredibly similar.
I looked it up. All 96-01 GT Mustangs used T-45 trannys. The 3650 is used in the new Mustangs.
Justin B. Yost |
mach 1s = 03-04 = 3650
which is what he did the swap in
Oh I thought you were referring to my car, not his. My bad. And I guess no answer yet? =(
Justin B. Yost |
mm's nitrous mod
2000 mustang gt
the swap will need to be donw to a t45 or t5, i dont think there is a mechanical 3650 option.
t45.
1997 Mustang GT
13.56@102.94
![]() iTrader: 1 reviews
I did this swap way back in like 1999, so I hope I can recall all the BS I had to do.
PCM, you can get a tuner to shut off the auto trans functions in your stock PCM. If you don't, the car will run and drive fine since the trans is controlled separately from the motor, but you'll fail emissions testing since you'll have a check engine light and a bunch of trans codes along with a flashing OD light. You'll need a manual trans harness. There is a brake/shifter interlock cable that needs to be removed. Manual pedal assy and you might as well do the HD clutch quadrant while it's out. I did the firewall clutch adjuster, too. Ford HD clutch cable Make sure the T45/TR3550/TKO has the clutch arm pivot stud and if not get one. Clutch fork and cover for the bell housing Flywheel Clutch kit with alignment tool, pressure plate, clutch disk, and throw out bearing Pilot bearing Ford OEM flywheel bolts (don't go buy any from Lowes because they might not be proper grade and if they snap off your clutch and flywheel will become a saw blade through your floor board). Ford OEM pressure plate to flywheel bolts (Ford OEM only see above). Ford OEM Manual trans bell housing to block bolts Clutch dust shield thingy T45, stock or after-market shifter. If you go TR3550/TKO it supposed to have a nice shifter already. I used a B&M ripper on mine anyway. You'll need the leather shifter cover and a shift knob If you go T45, the trans cross member will need to be relocated rearward, However, if you go with a TR3550/TKO, it will bolt right in. That is if the new TKO has the rear support in the same place as my older TR3550. If you reuse your stock DS and install the TR3550/TKO, you'll need the correct spline yoke and a DS spacer. If you go TR3550/TKO you'll also need a bell housing. Your speedo gear should work fine, but look it up in ford parts catalog to be sure. Trans fluid per manufacturers specs. It's easier to fill it through the shifter for the 3550/TKO once you gt it in the car. That's all I recall for now. Disclaimer: It's been about 8 years since I did this swap so make a list and double check everything I've listed to be sure before you start this. I used two floor jacks, jack up the car about 3.5-4ft off the ground, supported it with 6 huge jack stands and two ramps, plus foundation bricks under the tires just to be safe. Tips: (1) Auto trans is heavy, drain the fluid! (2) trans are shipped dry so don't forget to fill it up! (3) I had to notch maybe 1/4' from the shifter hole in the trans tunnel to clear the front of my B&M Ripper Shifter. (4) It's best to get a leather shifter cover from a j/y since it comes with the plastic lower part attached. If you just order the leather cover, there is no way that I know of to connectit to the plastic auto shifter cover. (5) Get a manual and TQ every F'n bolt to spec! Don't F**k around on this! (6) Use Loctite where rec'd by Ford in the service manual. (7) Support that car well and have someone keep a regular check on you while you're working under that car. Good luck!
![]() 1997 Mustang GT Aluminum Block PI swap & 4R70W to TR3550 swapped. Best 1/8: 2.04 60ft 8.74@81.85 & Best 1/4: 2.045 60ft 13.56@102.94 all on stock 245-17's My Garage Last edited by JohnC; February 10th, 2009 at 02:02 AM. |
1994 Mustang 5.0
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
Well There you have it.
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
3rd Place '11 ROTY
'02 GR-40/SLA Saleen
19.34@42.259
T-56 ... T-56... T-56... T-56... T-56... T-56... T-56
.......... what? ![]() Jazzer
mm's nitrous mod
2000 mustang gt
fix't!
3rd Place '11 ROTY
19.34@42.259
![]() ... as a tranny, Jazzer is secure, oops..... I mean, wait a minute!
Threads Similar to: Auto To 5 Speed Swap. HELP!!!!
| Auto or 5-Speed? | pramiscal | 94-95 | 20 | January 17th, 2008 04:20 PM |
| 4.6 factory auto SWAP to new 5 speed | 89FoxGT | 96-98 | 2 | January 15th, 2008 12:59 PM |
| Anyone Know About Speed Shifters For A Auto? | jagstang89 | V6 Mustangs | 21 | September 22nd, 2007 05:43 PM |
| 93 2.3 Auto To 88 5.0 5-Speed | 808pony96792 | 5.0 Mustangs | 1 | September 11th, 2006 08:16 AM |
| auto bronco into 5 speed | 173speed | All Other Vehicles | 2 | March 17th, 2006 04:40 PM |
