1998 GT Mustang
N/A
Long tube Header's Help
I'm going to buy a set of long tube headers and need to know wat i need to do em right.
1997 Mustang GT
Are you planning on doing the job yourself?
![]() 1997 Mustang GT 1985 Mustang Gt 5.0-Sold |
you need alot of beer, ibuprofen for the headache, and icy hot for your rump.
97' GT 98' DSG Cobra |
1998 GT Mustang
N/A
yup, i got a set of PI heads and the headers to thro in with em
1998 mustang GT
14.02@98.25
i attempted to do it myself and with no avail. ended up towing it to a shop and 600 dollars later they were on. you need a shorty h or x pipe o2 extenders and 02 delete kit from american muscle. they are a pain in the arse to put on and if you have a lift and some mechanical knowhow you might get it. A impact wrench will also be nice to loosen the rusted bolts on the exhaust and heads. also get o2 sockets you can rent them for 25 bucks at a local autozone and you get the money back when you return it. ok now onto the install the passenger side you need to take just the pass side engine mount off and jack the engine up and sideways plus take the starter off to get the header in. if possible change the studs in the motor to the smaller ones because it makes putting the new nuts back on A LOT easier. you have to install the header and starter at the same time. For the driver side you need to undo the stearing shaft with one bolt and wd-40 the remove the dipstick so you can get the header on the motor. this one is also done from under the car. remember to change which engine mount bolts are on and jack the engine the other way. you have to lower the engine to tighten the bolts for headers because with the engine up the headers hit the bottom of the car. again this may be easier with the heads removed. if i missed anything just add it in.
1989 LX Coupe
7.1@99mph
Ill do it. Its easy.
1998 GT Mustang
N/A
could u say attach the header to the head and wiggle the head in place, i mean if it rly comes down 2 it ill jack the car up and drop the engine far enough to get em
Threads Similar to: Long tube Header's Help
| Long tube headers or short tube headers? | 2much4u | 99-04 | 20 | October 11th, 2009 10:49 PM |
| Long tube vs short tube headers Pros and cons | cams-shelbycobra07 | General Tech | 3 | July 16th, 2007 08:41 PM |
| short tube or long tube headers? | ishyton4bangers | V6 Mustangs | 6 | July 16th, 2007 01:37 PM |
| short tube vs long tube | Mustang RacR94 | V6 Mustangs | 17 | February 26th, 2007 12:42 AM |
| Long Tube/ short tube | OTreborO | 5.0 Mustangs | 4 | June 15th, 2006 04:21 PM |
