PI Swap Problems?
Old March 9th, 2009, 11:25 PM   #1
1998 GT Mustang
N/A
4.6LMadness is on a distinguished road
PI Swap Problems?
My friend seems to think im going to blow something apart with the 10.5 compression the car will make, any one can verify this or is it safe with stock internals?
Old March 10th, 2009, 12:17 AM   #2
ColdSteel's Avatar
97 Mustang GT
ColdSteel will become famous soon enough
Send a message via AIM to ColdSteel
yes 10.5 is safe. countless people do this swap.
97' GT
98' DSG Cobra
Old March 10th, 2009, 12:22 AM   #3
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
10.5 is VERY safe. ESP with Alum heads...
Old March 10th, 2009, 12:36 AM   #4
1998 GT Mustang
N/A
just thought id double check because my friend seems to think im going to blow a rod or something so he thinks he'll be laughing, but i should be the one laughing.
He's only driving a stock 94 cobra
Old March 10th, 2009, 01:15 AM   #5
ColdSteel's Avatar
97 Mustang GT
tell your friend hes an idiot.
insert cuss words where you see fit.
97' GT
98' DSG Cobra
Old March 10th, 2009, 01:22 AM   #6
1998 GT Mustang
N/A
gota love those 5.Slow guys, they are quite a crowd
What i dont understand is how that motor makes the power it does with intake ports as small as they are.
Old March 10th, 2009, 04:26 AM   #7
Smelly Fists, Socking Cocks
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
sounds to me like he's gonna be jealous of the 25 rwhp u'll have on him
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old March 10th, 2009, 05:20 AM   #8
jasons_98gt's Avatar
1998 mustang GT
jasons_98gt is on a distinguished road
Send a message via Yahoo to jasons_98gt
damn i had my pi swap on for about 16k already ITS SAFE so start laughing at his ass!
Old March 11th, 2009, 01:10 AM   #9
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
a friend just did his swap onhis 98. got a lil hot and itsprung a coolant leak. any ideas? it also ideled rally high when first started for like 5 or so min.
Old March 11th, 2009, 01:14 AM   #10
1998 GT Mustang
N/A
did he put underdrive pullies on? or is both coolant temp sensors connected?
Old March 11th, 2009, 11:33 PM   #11
Willy Mo's Avatar
only one temp sensor was connected at the time. He now is buying a new pi intake with aluminum crossover and gonna tap it for the second sensor. you think that was the problem?
Old March 11th, 2009, 11:36 PM   #12
1998 GT Mustang
N/A
absolutely, that other sensor sends information to the ECU. The car does not know when its warmed up or cold with out it.
So it will just dump random amounts of fuel into the engine and not turn the fans on at the correct time. The other sensor is just for the gauge
Old March 11th, 2009, 11:37 PM   #13
G.T. Rags's Avatar
Millenium Falcon
it wouldn't cause the leak
Old March 11th, 2009, 11:39 PM   #14
1998 GT Mustang
N/A
If it let the engine over heat and crack the intake then i would say it did cause the leak
Old March 11th, 2009, 11:51 PM   #15
G.T. Rags's Avatar
Millenium Falcon
i've personally run my car without the sensor hooked up when i broke it and all it did was make my ac not work and caused my fans to kick on constantly....
as long as one is plugged in it wouldn't overheat.
he's got a coolant leak because he didn't do the swap properly, bottom line
Old March 12th, 2009, 12:47 AM   #16
Willy Mo's Avatar
the leak was from the back driver side corner. we thought that wasthe case. but heard that you sometimes dont needthe other sensor hooked up. but heis gonna getherdone this weekend hopefully. names 98midnight if yous ee him on here ask him about it.
Old March 12th, 2009, 01:32 AM   #17
1998 GT Mustang
N/A
did you guys happen to put the gaskets back into the intake manifold? When you changed the main intake gaskets? were there any o-ring type things lying around?
Old March 12th, 2009, 01:43 AM   #18
Willy Mo's Avatar
shit i dunno. ididnt do the swap i just helped with some info its at some shop that he knows. i will ask and see tho. he said something about needing to put some silicone in the four corners of the intake.he said he read that in a write up.
Old March 12th, 2009, 01:46 AM   #19
1998 GT Mustang
N/A
that would do it. He put a PI intake on nPI heads didnt he?
With out the silicone its going to leak. No if ands or butts about it.
Old March 12th, 2009, 12:20 PM   #20
hbk_136 is on a distinguished road
not all 4 corner, but around the coolant ports.
Threads Similar to: PI Swap Problems?
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 05:33 PM
1995 351 to swap or not to swap.& how to? Jeffery9508 94-95 9 August 3rd, 2008 09:00 AM
PI swap problems?!? dc1515 96-98 18 June 20th, 2008 04:36 PM
Potential problems/issues with engine swap robz301 V6 Mustangs 22 December 26th, 2007 03:19 AM
HELP!!! PI Swap problems 97gtstang 96-98 5 April 19th, 2007 02:15 AM
