96 GT Cooling System Upgrade ?'s
I am looking to upgrade the cooling system on my 96 GT. I am going to buy a Fluidyne radiator, but I was told that there was a factory upgrade from 96 to the 97 fan system. Anyone know what the differance is, and if it's worth changing with the new radiator? If so, does a 97 Fluidyne part # need to be ordered since it is differant for the 96? I assume the differance is in the fans, and not how it mounts. Thanks
You are in luck.........
I just bought the SA Design "How to Build Max Performance 4.6-Liter Ford Engine" book. It covers that topic..........And I quote.."The '97-up Mustang cooling fan and shroud flows well, and does a good job of cooling in traffic. '96 Mustangs can be upgraded with the '97-up radiator, fan and shroud for improved cooling".I plan on going the route you did with the flowdyne, but using the upgraded fan and shroud. BTW where did you buy your radiator?? I was looking at Summit but they are just a tad $$.
God I love my GT !!! |
Oops sorry didn't answer question, no kit!! Aslo you can use an electric fan set-up from a lightening pickup, book says it'll give 5 to 7 rwhp more.
Thanks for the info. I found a seller on Ebay selling the radiators for $383.00 which includes shipping. The sellers user name is raceoptions. That is the best price I have found so far. I'm not sure what the Lightning fan would do that would give the extra HP. It seems both fans would draw about the same amps. I think I'll look for a 97 setup and order the radiator for a 97 unless anyone else has any other ideas. Thanks.
MM's Coffee Addict
The 97-98 radiator is far better than the 96's: and that is the reason why there was a recall on many 96 Cobra models due to issues with overheating in those 96 models, uprading them to the much improved 97 OE radiator.
![]() Vortech V2, intercooled @ 10psi. Maximum Motorsports supsension goodie bag car less roll cage. Built '04 IRS. Hodge-podge of Roush/Stalker panels. |
Thanks for the info. Does anyone know if the wiring harness is the same for the 97 fan as for the 96?
Threads Similar to: 96 GT Cooling System Upgrade ?'s
| Fuel System Upgrade??? | 95blackbeauty | 94-95 | 1 | September 5th, 2007 04:31 PM |
| moping up the cooling system | usmcsawgunner | 5.0 Mustangs | 4 | July 2nd, 2007 02:28 PM |
| 07 cooling system upgarde | dumps | 2005 - 2010 | 2 | May 29th, 2007 11:03 PM |
| Ignition system upgrade | Dj1123 | V6 Mustangs | 1 | May 14th, 2007 11:33 AM |
| whats the best cooling system CLEANING method before........ | 95oldyeller | 5.0 Mustangs | 1 | February 13th, 2007 08:12 PM |
