1998 mustang GT
14.02@98.25
oops!
when i was installing my new gears i didn't check the backlash on the pinion or the diff. now i have gear whine. is there a way i can go back and fix it. i only have 50 plus miles on the new gears
Pypes LT, BBK o/r h pipe, Flowmaster 40 Series, SCT Tune, 4.10 Ford Racing, H&R SS springs/ Eibach shocks, 10.5x17 nitto 555r's and 9x17 nitto 555's |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
pull the cover and check backlash and gear pattern. not too bad if just backlash is off. you can reset the shims and correct it.
1998 mustang GT
14.02@98.25
i don't know if i just over worried but i feel the gears in my stick when under deceleration also the whine is only under decel. i might be under acel but i don't hear it over the exhaust. i did check the gear pattern before i put the cover on and it set deep but not touching the bottom of the ring. it wasn't quite center on the teeth but it was damn close.
1998 mustang GT
14.02@98.25
also how do you fix the speedo?
I believe for yours you have to get a speedo gear
![]() Pretty.............................Slow Mods: Apparently more than 250 characters |
1998 mustang GT
14.02@98.25
damn i was hoping that wasn't the case, can a livewire tuner also change it?
Pypes LT, BBK o/r h pipe, Flowmaster 40 Series, SCT Tune, 4.10 Ford Racing, H&R SS springs/ Eibach shocks, 10.5x17 nitto 555r's and 9x17 nitto 555's Last edited by justin025; March 23rd, 2009 at 09:39 PM. |
Its not that expensive if I remember correctly
1998 mustang GT
14.02@98.25
100 bucks.. i already have a tuner so if that does work with a custom tune then there is no need
Abyssinian of AX
'02 Saleen
19.34@42.259
A tuner won't help you with a pre-'99 Stang, you have a mechanical speedo.
When I went with 17"s on my '85 GT, I had to install a new speedo gear in trans. Was VERY easy to do and solved inaccuracy issue. I was off by 5 mph at 70 mph, so was all good. Contact Ford and they can do the math for what gear you need. Was like $15.00 if I remember correctly and was like 18 years ago. Jazzer
1998 mustang GT
14.02@98.25
so i found the gear, now to figure out how to install it....
Abyssinian of AX
'02 Saleen
19.34@42.259
^ tis easy
![]() Just jack the car up and remove the speedo cable from drivers side of trans (was on drivers side of my T-5 back in da day) You should get only a little trans fluid out, but cannot say for certain as you probably have a T-45 and may be different. The gear is only held in by a small clip and took all of 10 miniutes to do. Check out ***THIS*** page for some good info Jazzer
1996 GT Convertible
13.88@100.71
+1 on the speed gear change.
On our cars (96-98) you can fix the speedo 2 ways. 1) with the gear ... $10-$20 ... Speedometer Recalibration Gears - '79-'98 Ford Mustang 2) with the speedcal ... $100 ... Speed Calibrator - SpeedCal at AmericanMuscle.com - Free Shipping! The speedcal is supposed to be more accurate.
![]() Mods: Katzkin Leather, MMR stage II heads w/PI cams, PI intake, Accufab 75mm TB & Plenum, CAI, Ram HDX clutch, Pacesetter LT's & X pipe, Pypes hi-flo cats, Flowmaster cat back,3.73 gears, Sct SF3 tuner, Mamba M2's |
1998 mustang GT
14.02@98.25
well my speedo was off by 5mph before the gear swap, and its 5mph fast so its a safeguard for me not to go over the speed limit
ad now back to the gear whine... ill see if i can get audio of it, and when i take it apart take pics of the gear marking compound to show the gear pattern
Abyssinian of AX
'02 Saleen
19.34@42.259
^ over time, you will falsely "add" mileage to your ride, so I recommend you correct it.
Jazzer
Just looking...
![]() iTrader: 1 reviews
I also have gear whine under decel on my car with 4.10s. My backlash is set up correctly. So even when your car is set up right you may still get some gear whine. My gears do not stick though, so that might be a reason to go back in yours.
'97 GT
I heard yesterday from a reputable mustang shop in my town, that both richmond and motive gears will whine due to the company cutting corners. They said the only gear worth putting in is FRPP. They said no matter what, with richmond it will whine, and with motive they had to re-mark add shims, drive, add shims, drive, add shims, and they said it still had a whine after it was set perfectly!
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
a speedo gear is 7.99 from the local ford dealership. and its simple to pop in. and if you have an auto i believe the sct might work, but if its a 5spd, then no it wont.
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
#18 | |
Just looking...
1998 mustang GT
14.02@98.25
yes they are ford racing gears from AM. looks like i won't be able to do it till this weekend, which sucks. for the crush sleeve can u pick that up at any local store?
1997 Mustang GT
Faster than an s4
It could also be that your car is just spinning more rpm's. You are spinning 25% more revolutions per tire turn now than you were stock.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
Threads Similar to: oops!
| oops lol | HMUSN | The Clubhouse | 7 | June 19th, 2008 02:31 PM |
| oops, n2o backfire | SWEET2KSTANG | 99-04 | 67 | March 20th, 2008 03:19 PM |
| oops | WilltheThrill | Modular Mustangs | 3 | July 14th, 2007 12:41 AM |
| OOPS | AtxStang | 99-04 | 12 | July 22nd, 2006 11:43 PM |
