windsor heads?
Old April 2nd, 2009, 02:49 PM   #1
Boostang's Avatar
1997 Mustang GT
11.01@128.32
Boostang will become famous soon enough
Send a message via AIM to Boostang
windsor heads?
i was told i was able too ues my 97 timing cover with these heads for my pi swap and that all i needed were the longer bolts?!
can anyone tell me if this is true or not!?
thanks!
If It Dont Flow It Wont Go!!!
forged pistons,teksid block and a romeo cast cranks for sale.. pm if interested..
selling them for next too nothing
Old April 2nd, 2009, 02:50 PM   #2
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Do yourself a favor and stick with Romeo parts.
Old April 2nd, 2009, 03:10 PM   #3
Boostang's Avatar
1997 Mustang GT
11.01@128.32
is there a flow difference between the two?
i've already purchased these heads..
Old April 2nd, 2009, 03:16 PM   #4
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Really no performance difference. The bolts are different sizes and the cam retainers are inferior IMO.
Old April 2nd, 2009, 04:44 PM   #5
1998 GT Mustang
N/A
4.6LMadness is on a distinguished road
Wrong, Romeo cam caps are worse. They have girdles connecting the caps and they tend to crack. Windsor heads use individual cam caps. You dont need longer bolts just bigger ones. m10 1.5 and you will need 8 of them. 4 are studs and the other 4 are regular bolts.
Old April 2nd, 2009, 04:48 PM   #6
1998 GT Mustang
N/A
all 8 are suppose to be studs but you really only need studs for the top part of the heads because that is where your accessories mount. Not quite sure why the other 4 are studs but it will save you a couple bucks by not purchasing them.
Old April 2nd, 2009, 05:31 PM   #7
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
I second that. Why else would Ford use the same style cam caps on the GT heads...Ford GT that is...
Old April 3rd, 2009, 12:47 AM   #8
Boostang's Avatar
1997 Mustang GT
11.01@128.32
so i dont need to purchase another timing cover right?
Old April 3rd, 2009, 12:48 AM   #9
1998 GT Mustang
N/A
nope the difference is inside the timing cover not out
Old April 3rd, 2009, 07:43 AM   #10
MM's Mad Scientist
acmillr's Avatar
Slow Fella
I believe that this thread will help give everyone an idea of how much knowledge and mod motor experience this guy has.
Old April 3rd, 2009, 07:43 AM   #11
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Way different material.
Old April 3rd, 2009, 09:00 AM   #12
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
and here we go.............
Old April 3rd, 2009, 10:03 AM   #13
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Sorry Sweet, I didn't realize this guy was the technical power house that he obviously is. I'll make sure and keep my mouth shut from now on. This fella' definitely has his shit together on this whole mod motor thing.
PI heads out of a 2000gt mustang wouldnt fit my block would they, am going to need the whole engine? 98GT is wat i drive
from wat iv come to understand tho is the bolt pattern on the windsor heads are different than ares are
When you port out heads is it a "must" to have them chemically dipped to get the metal shavings out or is an air compressor and a rag good enough?
Ok i got my PI heads today and noticed something odd, i'm missing to rollers and i guess some sort of spring. Not the valve spring but the other one beside it.
My question is, can i use two off of my NPI heads?
Is the oil pressure suppose to fluctuate with engine revs or dose are motor have that on/off switch the trucks have. You either have enough so it looks normal all the time or your low and it shows no pressure.
My favorite by far.....
My friend seems to think im going to blow something apart with the 10.5 compression the car will make, any one can verify this or is it safe with stock internals?
Old April 3rd, 2009, 01:15 PM   #14
1998 GT Mustang
N/A
you mean to tell me its impossible for someone to learn? iv done a lot of reading and just sharing what i know about the heads. There is no need to be a dick. I'm not telling him how to install them asshole.
Old April 3rd, 2009, 01:33 PM   #15
1998 GT Mustang
N/A
And i dont see the problem with half those questions. I think its very sensible to learn a bit before you decide to do something. This guy is just wanting to know if his heads would work and here you are bashing his thread with stupid BS like this. I doubt you were born with a brain full of knowledge that god himself deiced you were fit for. We all started somewhere but nope not you. Genius from birth. If your going to flame me do it in a PM, dont jack up his thread with stupid bullshit like this.
Old April 3rd, 2009, 01:41 PM   #16
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Just setting the record straight. I don't want you to be giving out info like you are some kind of technical wizard with a degree in metallurgy. If you feel as though you genuinely possess the knowledge you are advertising, you have no reason to get defensive. Thanks for taking the time to reply.
Old April 3rd, 2009, 01:48 PM   #17
1998 GT Mustang
N/A
............All i did was tell him the heads would work and what extra pieces he needed, and then out of nowhere....BAM.....you with a butt ton of BS that is completely irrelevant to this thread. I never once claimed i know everything. Nor do i think i do. Why else would i still be asking for help when i have problems?
Old April 3rd, 2009, 01:49 PM   #18
1998 GT Mustang
N/A
What record?!
Old April 3rd, 2009, 02:46 PM   #19
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Given your obvious limited knowledge on the subject, I don't see how you know that "they tend to crack". Perhaps you could offer some specific examples of where you have seen this happen.
Old April 3rd, 2009, 03:41 PM   #20
1998 GT Mustang
N/A
Pictures and other post on the web is where iv come across this knowledge and it also seems to be a wide spread belief that the romeo cam caps are inferior to Windsor. Iv yet to see any evidence of Windsor cam caps failing. If the romeo cam girdles were such "High quality" why were they tossed aside for individual cam caps in the new 3v GT's?
Threads Similar to: windsor heads?
Romeo or Windsor heads ssprofession 96-98 2 February 1st, 2009 01:43 AM
Romeo or Windsor Heads jrfan4life 99-04 10 November 17th, 2007 05:16 PM
Difference between windsor and romeo heads suds488 96-98 0 October 30th, 2007 05:29 PM
