1996 GT Convertible
13.88@100.71
I got to cut something ... can I ?
The passenger side collector touches on the k member. Kinda of.
![]() It is hitting on the "clip" that is used for a nut, understand ? The K member bolts screw into clips not nuts. It hits this clip. Not sure if I can get a nut on top so I was thinking about torching the "U" part of the clip off. Besides just being a bitch to remove that K member bolt later if needed. Do you think it'll lead to any troubles. The header might still move the 1/8" over and touch the actual K member after I cut the clip and give it the opportunity.
![]() Mods: Katzkin Leather, MMR stage II heads w/PI cams, PI intake, Accufab 75mm TB & Plenum, CAI, Ram HDX clutch, Pacesetter LT's & X pipe, Pypes hi-flo cats, Flowmaster cat back,3.73 gears, Sct SF3 tuner, Mamba M2's |
1998 GT Mustang
N/A
Invest in a tubular K-member
1988 GT
Not so sure what you want to cut without a picture but as long as the clip still clears those threads... you should be alright. Then again parts are meant to fit with-out cutting sh*t apart. Pictures would help though.
1996 GT Convertible
13.88@100.71
I'll try to get some pics.
I've been trying to get to my buddy's garage to use his pit, but his mom passed away last week. I want to check on my clearances while the car is still sitting normal, not jacked up on one side and all twisted.
Threads Similar to: I got to cut something ... can I ?
| had to cut | gooberhead320 | The Clubhouse | 7 | January 6th, 2009 03:22 PM |
| has anyone ever CUT!!!!!!!! | show95stang | 5.0 Mustangs | 3 | March 25th, 2008 12:21 AM |
| cut wire | jh3rlh | 5.0 Mustangs | 2 | April 12th, 2007 07:07 PM |
| Y Cut-out | TheChariot9923 | General Tech | 11 | March 14th, 2007 06:29 PM |
| Cut-Off Mufller? | V6RedMustang | Pictures | 2 | January 14th, 2007 11:49 AM |
