swapped but won't start
I have a 97 mustang gt that did have a 4.6 and 4R70W, now it has a 5.4 SOHC and a 99 Cobra T-45. It's 95% or more complete. I just have to reconnect the tranny wiring. The question is..it won't start, just to check if it will turn over. I was told there's a neutral safety switch that i need to look at. I found something off of my steering column, a wire that ran to the old gear selector ( park, neutral, reverse) it has a 3 wire connector on it also, is that the neutral safety switch? looking at the haynes manual in the back of the book, there's a schematic of the starting and charging system. at one point it showes the transmission range sensor, that's located on the old tranny, plays apart in the starting of the car. So, if that's not there anymore, what do i need to do? i also replaced the PCM with ford racings 96-97 HP PCM. so the TRS shouldn't play a part in it now, right? any one know?
1988 lx t-top
if it wont start cause of the nss two of those wires put together will bypass the nss and it will start in any gear. Does it turn over?
it won't turn over at all. I think i'll tie the two wires together and if that doesn't work,i'm going to bypass everything so it runs from the ignition to starter
I figured it out.
what was the problem ?
![]() SEEYAAAAAAAAAAAAAAAAAAAAA MOTHER @#$% |
it was tired and not ready to start
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
My Stallion is Bigger!
I have seen a navigator motor 5.4 sohc in a stang before had a NOVI 2K strapped to it. Power was in the 600's you should be happy with that motor.
From what i here they become massive torque monsters. nasty power
wish i had the patience to do one of these swaps
Yeah it was CROWDED in that engine compartment. I have a swap of my own going on right now but it is on a much smaller scale but should be a head turner. V6 to V6S/C from a supercoupe.
my moms is a sixer and it is supposed to have a sc on it sometime in the near future . hers is very clean a 95 with 75000 on it auto. babied badly
hope to see some pics of your projects soon. good luck
#11 | |
![]() When I bought my 95 V6 ![]() Now ![]() When I bought my 95 V6 ![]() Now with 120k on the chassis and 50K on the motor.
nope im new here.
does look nice it is the same color as my moms mine is the darker green they look good together.
Threads Similar to: swapped but won't start
| PI Swapped vs. 99-04 | RandoGT | 96-98 | 23 | October 1st, 2007 08:40 PM |
| Can oil pump shaft be swapped from the top?? | noyz25 | 5.0 Mustangs | 2 | July 29th, 2007 12:30 AM |
| Swapped my New Engine! | oasr87 | V6 Mustangs | 21 | July 24th, 2007 01:43 PM |
| PI Swapped Intake Manifold | 98vortech | 96-98 | 5 | October 25th, 2006 03:38 PM |
| PI Swapped Motor | 98vortech | Modular Mustangs | 7 | September 19th, 2006 06:24 PM |
