HELP !! Im confused
So i want to change the trans fluid on my recently aquired stang and it is a 96gt with t45 right ? I have read through several posts on here and most people say to use 3.3 ish qts of fluid on a change , but i found the specs to require over 6 quarts . So how much should i use ? I am gonna use mobile 1 synthetic
1997 Mustang Cobra
1/8 - 8.89@86mph
![]() iTrader: 1 reviews
well when you change your trans oil you can only get out the fluid thats in the trans. there is still gonna be fluid in the tq converter. so 3.3qts is about right. but if you want it all changed take it to a tranny shop. they have a system that pumps all the fluid out n pumps in the same amount at the same time!.
![]() Modifications and pics in my Garage... Reps Appreciated!
a t45 is a stick isnt it. so no torque converter so 3 qts of royal purple will be good.
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
Yes you do have a T-45 if its manual. The manual doesnt have a converter and you cant flush it with a machine because it doesnt use line pressure. I bought 4qt's when i did mine and i used Mobil 1 as well. Quick tip, recommend getting a short throw shifter with it because changing the fluid is a tight squeeze and trying to get it in sucks with a bottle unless you buy a fluid pump.
I took my shifter off and took out both drain and fill. Drained it, then put the drain plug in and then poured the fluid through the top of the tranny where the shifter goes and then let it drain out the fill and then put the plug back in and installed my shifter. Very simple. Good luck
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
#5 | ||
3qts.
thanks guys , , i did get a b&m pro ripper and did the oil change using 3.3ish quarts and everything is good ! Easy job .. I can already feel an inprovement in shifting , but that i suppose is more the shifter then the fluid change
.. Man that shifter ROCKS !!!
http://www.myspace.com/jryotas |
Threads Similar to: HELP !! Im confused
| I'm a little confused... | D-Brow | General Tech | 4 | July 26th, 2007 08:25 PM |
| Ok, confused about this: | shroom | 99-04 | 61 | April 1st, 2007 06:30 PM |
| somewhat confused | sirpullsalot | General Tech | 4 | January 16th, 2007 11:12 PM |
| Please help me im confused | Blue98GT | 96-98 | 0 | December 30th, 2006 07:43 PM |
| confused | mustang1072 | V6 Mustangs | 5 | December 27th, 2006 10:55 AM |
