5.4L rebuild parts check
Just making this thread for anyone to help me make sure i got all the parts i need ;>
Going from NPI to NPI stock rering/bearinged bottom and PI top end These are the deals ive found Head Bolts - 45 for all of them new - ebay Heads - 250 w/cams -Salvage- Cams Will be for sale cheap when i get the heads Head Gasket Kit - $101 -Multi-layered steel head gasket/Exhaust manifold gasket/Intake manifold gasket/Valve cover gasket/Viton valve stem seals/Camshaft front/O-rings/Other Small Gaskets - Ebay Rod Bearings - 150 - Summit Fuel Injector Seals - 13 - Summit Main Bearings - 45 - Clevite TM-77's - From Rock Auto Crankshaft Seal - 11 - Fel Pro - Rock Auto Timing Chain kit - 195 - Cloyes - Rock Auto - Crank, Chain (2), Guide (2), Tensioner (2), Tensioner Arm (2) in kit Rings - 60 - Ebay Cam w Springs - XE270 w behives and steel retainers - 820$ Tune - 400 for chip and the tune no matter if it takes 1 hr or 1 week ;> now if anyone can fill me in on anything im missing or where to find any better deals that would be great ;> if someone could price a rering kit with new timing components and main bearings for cheaper let me know ;> so far my rough total just for the rering is 625$ i beleive $1695 w/heads/cams w/o tune and 2100 total after tune probaly 2500 once i add in Hot tanking engine and crank and possibly turn or polish on the crank only paid 158 bucks for the engine and the cylinder walls were excellent but heads were in rough shape and its a 97 block ;> with maybe a total of .001 or so extra bore from ring wear ;> cant even catch the ridge at top of cylinder with a finger nail to give arough idea
____________________________________________ 97 Stang GT 5sp 5.4L SOHC 96 F-250 Stroker -=-Modded-=- 08 Kawasaki Brute Force 7504x4I Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts. Last edited by 97stanggt; April 16th, 2009 at 10:49 PM. |
1/8 7.95@82.43
Im guessing you got everything hope the build goes well!
1997 SVT COBRA
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
Why So Much?
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
The came is 570 on ebay the springs 200 and retainers are 50
if you know someplace cheaper please do let me know
____________________________________________ 97 Stang GT 5sp 5.4L SOHC 96 F-250 Stroker -=-Modded-=- 08 Kawasaki Brute Force 7504x4I Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts. |
Threads Similar to: 5.4L rebuild parts check
| Tranny Rebuild - Where should i get parts? | The Novice | 5.0 Mustangs | 8 | March 23rd, 2009 05:12 PM |
| Rearend Help? Gears Rebuild Parts... | fordrarities | 5.0 Mustangs | 11 | February 29th, 2008 07:09 PM |
| Full Rebuild Parts? | sorrowfulkiller | 96-98 | 1 | November 21st, 2007 09:30 PM |
| Parts cleaning for engine rebuild | Buttaz | General Tech | 2 | August 10th, 2007 12:57 PM |
| Parts cleaning for engine rebuild | Buttaz | V6 Mustangs | 8 | August 5th, 2007 11:02 PM |
