Quick Q for the turbo guys
Old April 19th, 2009, 11:23 AM   #1
keiken's Avatar
keiken is on a distinguished road
Question
I need some input from the turbo guys here, i have a custom setup being built, and i need to know what to do with the oil vent line (pcv) coming from the drivers side head into the intake tube, should i put a check valve in it, just go to an open air breather (stand alone one sits on the top) or hook it up normal, i cant see doing that and pressurizing the crankcase, cant see it being a good idea anyways. also the EGR tube that was on the drivers side manifold isn't hooked up right now, wondering if deleteing that will kill my mileage or hurt my motor. just looking for some input on how your guys turbo systems are setup. thanks in advance for your input
Old April 19th, 2009, 11:25 AM   #2
HMUSN's Avatar
iTrader: 9 reviews
the EGR is for emissions. Don't worry about it, hell delete it. I would go with a breather and a catch can.
Old April 19th, 2009, 11:46 AM   #3
keiken's Avatar
yeah im thinking bout just doing it that way just for ease but i dont lke the idea of a catch can, i hate when i park somewhere and a small oil stain appears (you know if i got a spill or leak)
Old April 20th, 2009, 03:41 AM   #4
10.887 @ 127.89
S197Mach1 is on a distinguished road
Delete the EGR. Either run a breather on the valve cover and cap the manifold port or put a check valve into the line so you don't pressurize the crankscase under boost. Either way works fine.
Old April 20th, 2009, 02:57 PM   #5
1996 mustang gt
unkown
jchr96gt is on a distinguished road
run a breather on the valve cover.
play it safe!
Old April 20th, 2009, 11:39 PM   #6
keiken's Avatar
thanks for the imput, is there anything else required to be done with the egr other than just capping it? vaccum lines, etc? im assuming no but thought id just put this out there
Old April 20th, 2009, 11:48 PM   #7
LaserRed97GT's Avatar
1997 Mustang GT
14.92 before current round of mods....
LaserRed97GT is on a distinguished road
I'm assuming your ride is 1996 or later (OBD2) If you just cap the EGR, you will set a MIL code like P1407 EGR No Flow Detected, or P1408 EGR Flow out of Self-Test Range. The only way I know to get rid of this event is to have a custom tune done to stop the PCM from performing those functions. You can do it yourself with a Tweecer.
Old April 21st, 2009, 03:04 PM   #8
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
^ Correct, but i'm sure he can get it taken care of when he gets it tuned for the turbo
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
Old April 22nd, 2009, 12:49 AM   #9
10.887 @ 127.89
Exactly. It will need a custom tune anyway so the tuner can turn that off.
Old April 22nd, 2009, 10:26 PM   #10
1997 Mustang GT
Yeah, true. Might as well dump the evap purge as well, get rid of that stuff, and save some weight on the front end!
Old April 23rd, 2009, 03:12 PM   #11
Genibus Nitito Canus
HBK_2007's Avatar
2009 Ford Mustang GT
next year
HBK_2007 will become famous soon enough
Send a message via MSN to HBK_2007
would anyone know where i can find compressor maps for AiResearch turbos?
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about
Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, muffler delete
Threads Similar to: Quick Q for the turbo guys
Turbo timers and Boost Controllers? Turbo guys where you at? 95StangSVT General Tech 14 July 11th, 2008 08:01 AM
Quick turbo ? BDaily V6 Mustangs 20 April 18th, 2008 02:56 PM
tma turbo help QUICK!!! emgjsdk1 V6 Mustangs 10 March 14th, 2008 03:12 PM
ok quick question guys natedawgishot 99-04 11 February 4th, 2008 06:22 PM
Turbo Stang Guys Quick Question? e3sean 5.0 Mustangs 1 November 21st, 2007 04:43 PM
