1996 gt 97cobra boltons
help air/fuel ratio
my air/fuel ratio on the left bank is 20.7 at idle but gets a little better with more rpms and it has blue/white smoke at idle and low rpms i have a code that says my o2 isnt connected but i checked it and it seems ok and think i have bad exhaust valves dont know what to do??
Blue/whiteish smoke usualy signifies burning oil i think maybe valve stem seals are bad? and maybe 02 is bad also? get a live scan scanner where you can view the o2 readings and see if its sending anything if not its time for a new one
____________________________________________ 97 Stang GT 5sp 5.4L SOHC 96 F-250 Stroker -=-Modded-=- 08 Kawasaki Brute Force 7504x4I Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts. |
KB'd GT
If you are burning oil you can coat the O2 sensors and they will not work right. Typically a car wont idle above about 18:1, and if it does it will barley chug along. I suspect the WO2 has a bad sensor as well. Do a leak down test to see whats up.
i just put the new sensor in about a week ago and i think the wires are crossed on it so im going to take it back and get another but it hasnt smoked like this since i put in the new sensor..
Threads Similar to: help air/fuel ratio
| Air fuel ratio | jgibby | 2005 - 2010 | 4 | April 7th, 2009 06:03 PM |
| Air Fuel Ratio | patro | 2005 - 2010 | 13 | January 18th, 2009 11:58 AM |
| Air Fuel Ratio | SoonerStang | 2005 - 2010 | 11 | October 31st, 2007 09:10 PM |
| Air/Fuel Ratio | 98GreenGT | 96-98 | 6 | October 12th, 2007 02:58 PM |
| Air/Fuel ratio | yellowgt5 | General Tech | 4 | December 4th, 2006 02:01 AM |
