Gutted converters? - Page 2
Old May 21st, 2009, 11:08 PM   #21
1979&1997 Mustang
79StangPace is on a distinguished road
Will exchange the plugs tommorrow and test again. Plug recommedations? I am using motocrafts now. single platinums i think.
1997 Mustang GT Auto, (Fenderwell CAI), O/R X-pipe, Flowmasters, 3.73's, tuner, 180*stat...
1979 Mustang, 302 .060ov, KeithBlack's, Comp's, Weiand Stealth Intake, Holley 650dpr, 2800TCI, Hedman LT's, Flows, 410's, Welds, M/T Slicks and More..
Old May 21st, 2009, 11:12 PM   #22
1997 Mustang GT
97stanggt is on a distinguished road
Send a message via MSN to 97stanggt
follow all wiring from the connector on the coil to the ecm i searched on f-150 forum and this was usualy caused by broken wires of the wires running close to something with an electro magnetic field that disrupted the ignition signal
follow the wires first its cheaper ;> then do plugs on that side
____________________________________________
97 Stang GT 5sp 5.4L SOHC
96 F-250 Stroker -=-Modded-=-
08 Kawasaki Brute Force 7504x4I
Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts.
Old May 24th, 2009, 03:01 PM   #23
1979&1997 Mustang
Well, could not find anything in the wiring. Changed the plugs and the car runs almost normal. When I put the car in drive it dies a couple times before it holds idle. sounds funny when decelerating kinda like it has more backpressure than used to.
I also have a couple new codes, P0141 and P0161. Believe these are O2 codes but should I have these after I installed the Sims from american muscle? Do the O2's on the downstream have to be good for these to work? I did not change them, just installed the sims.
Old May 27th, 2009, 06:37 PM   #24
1979&1997 Mustang
anyone know if the O2's have to be good for the sims to work?
Old May 28th, 2009, 08:38 AM   #25
1997 Mustang GT
yes they should be good for the elims to work
Threads Similar to: Gutted converters?
interior is gutted mystang0673 99-04 11 November 29th, 2008 02:39 AM
gutted cats 1LOUDGT 2005 - 2010 43 April 16th, 2008 08:33 AM
gutted jwe General Tech 1 January 22nd, 2008 10:32 AM
gutted jwe 99-04 5 January 20th, 2008 11:53 PM
Gutted cats msolaas1 2005 - 2010 1 May 2nd, 2007 12:02 AM
