1998 mustang GT
14.02@98.25
slack in drivetrain
in first and second gear especially when i let off of the gas then hit the gas again it feels like there is slack and it bucks. is this normal or is there something wrong? i have 87000 miles. more importantly how do i fix it.
Pypes LT, BBK o/r h pipe, Flowmaster 40 Series, SCT Tune, 4.10 Ford Racing, H&R SS springs/ Eibach shocks, 10.5x17 nitto 555r's and 9x17 nitto 555's |
Do you notice your shifter move back and forth by getting on and off of the gas?
It could also possibly be a driveshaft, or a u joint..
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
my car jerks also but that seems to be a habit in the 5sp cars the 4.6 is a little jerky when u let off and get back on it in gear
____________________________________________ 97 Stang GT 5sp 5.4L SOHC 96 F-250 Stroker -=-Modded-=- 08 Kawasaki Brute Force 7504x4I Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts. |
1998 mustang GT
14.02@98.25
if the u-joint is going out would i be able to wiggle the driveshaft with my hand?
1998 mustang GT
14.02@98.25
my shifter vibrates when i drive but i thought that was normal, otherwise it doesn't move
#7 | |
! Post Entirely Way Too Much
a little shifter vibration is normal
Im topless, are you?
![]() ![]() Topless Mustang Club Founder Black Stang Crew Member #boobs out mods/pics BAMA Performance Drag Team #3 |
1998 mustang GT
14.02@98.25
ill have to get it on the lift tomorrow and check it out. about how much are they, should i just get an alum. one?
you can just replace the u joints and it should be cheap. not sure how much. if you get a new drive shaft go with an alum. one for sure.
faster than the stealth
iv noticed the same thing in my car. although my shifter shakes quite a bit. sometimes around a half an inch to 3/4 inch. although it still works fine so i never gave it too much thought.
1996 Mustang GT 5-speed sold.. ![]() ![]() http://www.youtube.com/watch?v=5VuRDQGk4k8 http://www.cardomain.com/ride/3340297 |
Pretty much seems like good ol' down shifting before matching up the rpms haha doesn't hurt ya but it will definetly jerk ya haha.
" There are alot of things to think about, but nothing to worry about " ![]()
1998 mustang GT
14.02@98.25
i know that will jerk but im talking about its in first or second you let off the gas still in gear then you hit the gas again and you feel the jerk from "slack" it gets progressively better as the gears get higher
1998 mustang GT
14.02@98.25
ok i found out what it was, when i swapped rear end gears i guess the crush sleeve wasn't tightened down or to tight and the driveshaft has alot of play. there is alittle leaking from the yoke and from the diff cover. when i put it in reverse there is sometimes gear grind. yes this does sound bad but im wondering if i just take it apart replace the crush sleeve will everything be ok. i have to drive it 400+ miles in the next few days so that kinda sucks but i have been driving it like this for awhile.... i know it seems kind stupid of me. so how bad is this?
Threads Similar to: slack in drivetrain
| Drive train slack | nolife | 5.0 Mustangs | 3 | August 27th, 2011 03:49 AM |
| slack in accelerator | bigbluemonkey | 99-04 | 14 | March 30th, 2008 07:28 PM |
| slack in gas petal | tom2000r | 99-04 | 13 | March 19th, 2008 09:11 PM |
| how to take the slack out of your gas pedal | wadepetersen | V6 Mustangs | 18 | October 4th, 2007 12:25 AM |
| Gas Pedal Slack? | postie | V6 Mustangs | 20 | January 2nd, 2007 05:30 PM |
