this a good idea?
Old January 23rd, 2007, 06:41 PM   #1
1998 GTvert
noppe180 is on a distinguished road
Send a message via AIM to noppe180
this a good idea?
70 MM Ford throttle body from 2003-2005 Lincoln Aviator 4.6L DOHC 32V 4V motor. Part number is 2C5U-9E926-AD. In very good condition.
Cheap way to upgrade your Mustang GT for more power. Probably the same as Ford Racing M-9926-D662 70MM throttle body (looks identical). Fits 96-03 4.6L 2V SOHC motors (as well as Aviator DOHC 4V motor). The Ford Racing throttle body sells for for $229 at Summit Racing. Buy this one at a bargain price.
Q: Would this be a direct bolt on, with no modifications needed to be put on a 2003 Mustang GT 4.6?
Jan-19-07
A: This will fit fine on a 2V GT motor. The only difference in appearance between this and the Ford Racing model is the lever where the cables connect. On the Ford Racing model the lever is steel (with plastic pieces) while this lever is all plastic. The position where the cables connect appears to be the same. You will need to put the throttle position sensor from your old throttle body on this one (2 screws). I've read several posts on Mustang forums where people have put these on GT motors and they work great.
40 bucks
or just pay 140 for 1 off ebay
Threads Similar to: this a good idea?
Ok so good or bad idea RhadCundell V6 Mustangs 22 October 21st, 2007 07:37 PM
good idea or bad idea? B0B 99-04 6 May 17th, 2007 11:18 PM
good idea or bad idea? B0B 99-04 2 May 17th, 2007 01:57 PM
good idea??? bad idea??? mustang1072 V6 Mustangs 19 January 25th, 2007 12:33 AM
good or bad idea? artisan00 V6 Mustangs 10 February 10th, 2006 01:23 PM
