check engine light help!!
Old May 15th, 2009, 07:22 PM   #1
rewadferger's Avatar
n/a
rewadferger is on a distinguished road
hey guys, just created an account here, but ,my roommate has been here before, but my question today is regarding a check engine light problem i am having. Last year i got a 125 shot put on and it blew out the stock cats, so i removed all 6 of them, then it blew the welds on the h-pipe so i replaced that with an upr x-pipe. and after i put on the x-pipe with no cats, the check engine light was not coming on, i even passed inspection last year and in texas the check engine light has to be off with nothing in the system to pass. But earlier this year the fuel pump went out in it so i replaced it with a higher flow, a 190, fuel pump. and ever since i replaced it, no matter what grade gas i use, the check engine light will come back on again and again after resetting it, saying its saying system running too rich bank 2. so its something to do with the fuel pump and o2. some say i need to go get it tuned to advance the timing due to more fuel entering the motor, or they say just get some mil eliminators for the o2 sensors. i am open to any ideas or suggestions, thanks.
Old May 16th, 2009, 01:11 AM   #2
1997 Mustang GT
97stanggt is on a distinguished road
Send a message via MSN to 97stanggt
running rich or lean will be the front 02s ...catalyst efficency low would be rear 02s which is what MIL elims are for...so ied say you need to replace the front 02s just do both at once and call it good
____________________________________________
97 Stang GT 5sp 5.4L SOHC
96 F-250 Stroker -=-Modded-=-
08 Kawasaki Brute Force 7504x4I
Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts.
Old May 16th, 2009, 01:19 AM   #3
330CubeGt's Avatar
1994 Mustang 5.0
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
Take the Bulb Out...
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old May 16th, 2009, 02:27 AM   #4
n/a
so replace the front o2s or just put mil elims on all?
96' GT
4.6L V8 2v non-P.I. w/ P.I. Intake
Ford Racing 3.73's, Aluminum Driveshaft, Hi-Flow 24lbs injectors, Hi-Flow Fuel Pump
Steeda Upper/Lower Arms, Under Drive Pulleys
Upr X-pipe, Magnaflow Mufflers w/turndown tips
Kyb Front/Rear Shocks
Old May 16th, 2009, 04:42 AM   #5
1997 Mustang GT
NO NO NO... putting mil elims on your front 02s will screw ur engine for sure replace front 02s with new and if u ever get a cat efficency low on either bank then put mil elims on the rear only
Old May 16th, 2009, 01:34 PM   #6
n/a
alright, i'll try that and let you know how it goes.
96' GT
Old May 18th, 2009, 12:40 PM   #7
5.8mustang's Avatar
1988 mustang lx
never ran down a track
5.8mustang is on a distinguished road
with no cats those 02s are reading straight from the engine prolly the root of the problem
Old May 18th, 2009, 05:49 PM   #8
1997 Mustang GT
he says its running rich or lean only the front O2s will throw those codes 5.8m so it has to be the fronts doing it the rears will only throw codes for catalytic efficency
Threads Similar to: check engine light help!!
Check Engine Light? 03_StangGuy 99-04 5 July 15th, 2008 01:04 AM
I need help...check engine light need4steed 2005 - 2010 9 May 14th, 2008 01:14 PM
Check engine light Dellbinder Audio/Video 4 October 29th, 2007 12:40 PM
04 GT check engine light mustanglover408 Modular Mustangs 2 October 14th, 2007 12:09 AM
Check Engine Light On Geezer 2005 - 2010 5 July 23rd, 2007 10:42 AM
