Transmision Question
Old May 18th, 2009, 04:07 PM   #1
fsttang96's Avatar
8.72 @ 81.68 1/8 mile
fsttang96 is on a distinguished road
What year did Ford start putting the Tremec Transmision in the Mustangs ? My problem is I bought a transmision to replace my 96's Borg & Warner and they said it came out of a 96 but its a Tremec . Now my speedometer is way way off so I took the speedo assembly out of my Borg & Warner and tried to put it in the Tremec but it didnt work ! It looks to me like the Tremec has an eye that watches something inside and the old one has a gear ! What do I have to do to fix this ?
1 of 829 made Bright Tangerine Orange
10Lb Vortech V2,CXRacing FMIC
MHS Stage 2 Blower cams,39# Injectors
PI Intake,Ported and Polished NPI Heads
BBK Headers,78mm BBK Throttle Body
Mac H Pipe,2.5 inch Flowmaster Exhaust ,373 Gears
Old May 18th, 2009, 04:29 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
borg warner is the same as the tremec's. the t45 that was put in from 96-early 01. the 99+ cars were electric speedo's, yours of course is gear driven. there should be no reason why you should have any issues at all if it came out of a 96-98. if the gear inside was changed out, that may be an issue. there will be a gear inside that you can see, the electric cars had a magnetic pick up ring that the sensor will read off of.
Old May 18th, 2009, 05:53 PM   #3
1997 Mustang GT
97stanggt is on a distinguished road
Send a message via MSN to 97stanggt
if its 99+ with the magnet i think your computer will need to be retuned to see it correctly? could be wrong
____________________________________________
97 Stang GT 5sp 5.4L SOHC
96 F-250 Stroker -=-Modded-=-
08 Kawasaki Brute Force 7504x4I
Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts.
Old May 18th, 2009, 06:21 PM   #4
330CubeGt's Avatar
1994 Mustang 5.0
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
Correct, thats what i have to do with mine.Before i just left it unpluged
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old May 18th, 2009, 07:17 PM   #5
fsttang96's Avatar
I have mine unpluged too ! 330CubeGt when you unpluged yours did your car want to stall when you came up to a stop sign ? Because after I unpluged mine it started stalling if I didnt give it a little rev right before stopping !!
Old May 18th, 2009, 07:28 PM   #6
fsttang96's Avatar
The transmission that I have now is the one with the magnetic eye . So apprently the guy that sold it to me didnt know what year it came out of because it is not a gear driven speedo . Also the tranny seems to be a better than the one that was in it . It shifts better and seems to have a shorter throw !
Threads Similar to: Transmision Question
transmision swap question beheivjer 94-95 13 July 27th, 2008 10:52 PM
Transmision question adrenaline=lifeline 99-04 5 May 8th, 2008 11:14 PM
transmision ? usspfnorman V6 Mustangs 6 October 30th, 2007 11:55 PM
transmision ? SilverGT04 99-04 30 September 8th, 2007 11:30 AM
Transmision parkershard 5.0 Mustangs 3 October 4th, 2006 11:24 PM
