check engine light
everything seems to be fine with the car. It idles and drives perfect, all the fluid levels are perfect, the exhaust it perfect, and all of a sudden the check engine light came on. The only known problem is an idler pulley but it hasn't had any effect (i'm replacing it most likely tomorrow or the next day). Does anybody know what this can be? And is there a way to check for what the problem is?
Thanks
![]() Black '93 Cobra Supercharged 306 |
I forgot to mention, its a 98GT
Priest of the Car Gods
I thought most OBD I systems had a way to put the computer into "tell me what the f***ing problem is" mode, and they'd flash the code to you (i.e. 5 blinks, pause, 7 blinks for a code 57). Not sure how to do that with your '93, though I'm sure someone else will.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
Oh, if it's a '98, then you just hook up an OBDII scanner. Harbor Freight has a decent one for under $100.
so i got it diagnosed at advanced auto and it turned up as the o2 sensors throwing the code. Considering there's 4 and they cost a ton of money, is there any way to pinpoint which one it is?
#6 | |
Pretty much any legitimate problem should throw multiple codes. My suggestion would be to clear the code, and see how long it takes to come back. A code has to be tripped 3 times in 3 different times of the car running before it will trigger the CEL; you may have an intermittent error that's occuring and not actually a bad 02 sensor. I have a similar issue with my cobra - Twice in ~3 years of ownership, I've gotten a CEL that's linked to the IMRC plates. But it's always just one code, and if there's actually a problem, 2 or 3 should be triggered. I clear the code, and it goes away for at least a year.
yea it hasn't come back all day. The i figure i can get at least 20k more mile on the stock o2's considering the car has 78k on it.
I just feel like a rookie with all this obd2 stuff because i'm used to my 93cobra haha
Heh, it's not that bad. A decent scanner goes a LONG way, though. I wouldn't go so far as to get a tuner for a '98, though most tuners do OBDII scanning, as there's not much to tune in those ECUs (you can bump up the rev limiter.... and that's it).
the code will come as like a bank 1 sesnor 2 or bank 2 sensor 1 and so on bank one is...pass side? bank 2 drivers sensor 1 is front 02 on that pipe sensor 2 is rear after cats online the 02s for NGK cept its not ngk its like ngt or something thats what i got for 36 bucks a sensor.
____________________________________________ 97 Stang GT 5sp 5.4L SOHC 96 F-250 Stroker -=-Modded-=- 08 Kawasaki Brute Force 7504x4I Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts. |
Threads Similar to: check engine light
| Check Engine Light...Again... | trueblue02GT | 99-04 | 10 | January 1st, 2009 11:12 PM |
| Check Engine light yet again! | mustangmanic | 99-04 | 14 | April 8th, 2008 09:56 PM |
| Check engine light | soccerboy08 | V6 Mustangs | 6 | February 5th, 2008 02:03 PM |
| Check Engine Light? | 97GT4.6 | 96-98 | 5 | December 20th, 2007 06:00 PM |
| Check Engine Light On... | Racerchik02 | V6 Mustangs | 34 | November 30th, 2007 01:27 PM |
