starting noises
Old May 26th, 2009, 01:08 PM   #1
zigbigadoru's Avatar
97 Mustang GT
slower than the speed of smell
zigbigadoru will become famous soon enoughzigbigadoru will become famous soon enough
starting noises
my car started making noises but its only when i start the car. its the the normal sound of the clicking when the starter is firing. it is a new noise and its very loud, and somewhat hard to describe. it almost sounds like a higher pitched clicking or something. i will be able to describe it more when i get home but can anyone think of possible things it might be?
Originally Posted by XTCNAGT View Post
That's what you get for excercising.
You think my lungs and chest hurt when I drive down the road for a triple baconator? No. You know why? Cause I'm smart.
Time for a nap.
Old May 26th, 2009, 01:10 PM   #2
1998 GT Mustang
N/A
4.6LMadness is on a distinguished road
The only thing i could think of is the flywheel. Buddy's truck did this before. turned out the flywheel was snapped or something like that and would spin freely from time to time.
Pi Swapped, K&N CAI, Diablo Tune, BBk O/R X-Pipe with Flow's dumped and a 5.4L on its way.
Old May 26th, 2009, 03:04 PM   #3
1997 Mustang GT
97stanggt is on a distinguished road
Send a message via MSN to 97stanggt
that could be but ied expect the car to shake....maybe the oil powered hydrualic timing chain tensioners are wearing out and its time for new causing the timing chain to be slapping a little my car does this to but im not worried it can blow the 5.4l should hopefully be done this week. but im not saying its gona crap can your car but unattended to in the future it can....idk why but 4.6l timing kits are expensive i got my 5.4l timing kit for 190 bucks with new crank sprockets chains tensioners tensioner arms and guides but they want 400+ for a 4.6 ;x wtf lol
____________________________________________
97 Stang GT 5sp 5.4L SOHC
96 F-250 Stroker -=-Modded-=-
08 Kawasaki Brute Force 7504x4I
Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts.
Old May 26th, 2009, 03:59 PM   #4
1998 GT Mustang
N/A
i say flywheel because his truck didnt shake or nothing. Just sometimes would spin freely when being started.
Old May 26th, 2009, 06:13 PM   #5
4.6L Coupe' 5spd
2002 BLK GT will become famous soon enough
Send a message via AIM to 2002 BLK GT
Its hard to describe if we don't hear a vid...
Old May 26th, 2009, 10:18 PM   #6
97 Mustang GT
ok i tried it a few times at work. it sounds like an asthmatic metallic sound. almost like when you have a chest cold and you wheeze but throw in some metallic-ishness to it.
Time for a nap.
Old May 26th, 2009, 11:42 PM   #7
1997 Mustang GT
sounds to me like timing slop i know my mark viiis i owned were notorious for it on start up cause the tensioners would bleed down granted thats also a 4v
Old May 26th, 2009, 11:43 PM   #8
1997 Mustang GT
im betting it sounds like a knock thats barely heard over the engine and not heard up the rpm band..
Old May 27th, 2009, 12:00 PM   #9
97 Mustang GT
it actually does NOT make the sound except for when starting. it really doesnt sound like a knock more like when the car is alrdy started and you hit the starter again i guess?
Time for a nap.
Old May 27th, 2009, 01:51 PM   #10
1997 Mustang GT
oh mine sounds like valve chatter right on startup then it slows to about a 1/2 second between each chatter then when warm goes away completely
Threads Similar to: starting noises
Loud Noises 2000ZincGT 99-04 7 September 22nd, 2008 09:16 PM
grinding noises? blue03mach1 94-95 4 July 3rd, 2007 07:57 PM
transmision noises El_Cangri V6 Mustangs 22 April 6th, 2007 03:14 PM
Weird Noises addict V6 Mustangs 17 February 8th, 2007 06:15 PM
Noises... Stan27 General Tech 20 June 22nd, 2006 04:06 AM
