96 Gt Cam Swap
Hi everybody we just istalled 270ah cams & pi heads. Now its seems to skip from 1500 to 3000 24lb injectors & sct tuner. need help
did the cams have to be degreed at all...;> most cams in these cars arent just plug and play friendly
____________________________________________ 97 Stang GT 5sp 5.4L SOHC 96 F-250 Stroker -=-Modded-=- 08 Kawasaki Brute Force 7504x4I Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts. |
yes we degreed them at 109
hmmm then no idea unless during dis/re assembly something got knocked loose clean MAF check O2 voltage with a scanner and such i guess
1998 GT Mustang
N/A
do you have an actual tune or just the canned tune?
![]() Pi Swapped, K&N CAI, Diablo Tune, BBk O/R X-Pipe with Flow's dumped and a 5.4L on its way. |
We Have Tried Adjusting The Tune But Little Change
1998 GT Mustang
N/A
Your going to need a custom tune at this point. The stock computer can only adjust for stock PI heads and cams. Aftermarket cams like those with the heads are going to need a tune to run and idle right. Not a canned tuned meant for the stock heads and cams.
MM's Drunken Sailor
i have aftermarket cams in my pi swapped car and no tune YET (hardley gets driven) all i had to do was adjust the throttle body to get it to idle perfectly. the stock computer doesnt open up enough to compensate fro the huge increase in air
![]() MILITARY CREW GSM3 |
Threads Similar to: 96 Gt Cam Swap
| Need some help on cam swap | bkg97gt | 96-98 | 15 | March 9th, 2009 04:44 PM |
| Cam Swap ? | ArmyChargedGT | 99-04 | 4 | April 15th, 2008 10:16 AM |
| Cam swap out | Lazyracer | 2005 - 2010 | 27 | October 19th, 2007 10:55 AM |
| pi cam swap | 97_stang_gt | 96-98 | 1 | June 10th, 2007 01:31 AM |
| 3.8l cam swap | mmvi | V6 Mustangs | 3 | March 31st, 2007 06:42 PM |
