What is a guy to do????
Old May 27th, 2009, 07:23 PM   #1
fsttang96's Avatar
need tuned
fsttang96 is on a distinguished road
Called and cancelled my PI heads because I was told it would run my compression up to 10.5 - 11.5 to 1 and it would not be wise to run a supercharger with that amount ! So I was just going to keep my NPI heads on swap out the cams for some PI (or some Comp Cams if the budget allows) and put on the PI intake so I could still run my SC ! Then I was told not to put the PI intake on NPI heads with a SC because I would have Intake gasket issues !!! How do I get more out of this car and still keep my SC on ?!?!?
P.S. Really dont want to run Nitrous !!!
P.S.S Dont want to spend thousands either !!
1 of 829 made Bright Tangerine Orange
10Lb Vortech V2,CXRacing FMIC
MHS Stage 2 Blower cams,39# Injectors
PI Intake,Ported and Polished NPI Heads
BBK Headers,78mm BBK Throttle Body
Mac H Pipe,2.5 inch Flowmaster Exhaust ,373 Gears
Old May 27th, 2009, 08:12 PM   #2
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Get a set of 2 valve SVO heads.
Or use thick cometic head gaskets with the swap to keep the compression down.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old May 28th, 2009, 07:44 AM   #3
1997 Mustang GT
97stanggt is on a distinguished road
Send a message via MSN to 97stanggt
use cometic thicker gaskets to lower cr on pis but PI heads will raise to 10.5ish and could still run bout 6lbs to it lil more i beleive if you add like a 25 shot of n202
____________________________________________
97 Stang GT 5sp 5.4L SOHC
96 F-250 Stroker -=-Modded-=-
08 Kawasaki Brute Force 7504x4I
Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts.
Old May 28th, 2009, 11:34 AM   #4
fsttang96's Avatar
need tuned
Were can I get a set of SVO heads and an intake ?
Old May 28th, 2009, 11:40 PM   #5
03 Mach 1 & 02 GT
2002 BLK GT will become famous soon enough
Send a message via AIM to 2002 BLK GT
I would say to try to get the phone numbers of junkyards close to you and start calling, I couldnt find anything online bro...
2003 Mach 1 Procharged 500rwhp club
Old May 29th, 2009, 06:00 PM   #6
1997 Mustang GT
not as slow... PI swapped :-)
mustangracer2g is on a distinguished road
svo heads are pretty rare nowadays, but yeah, i'd say if you want to do things right, do that, OR, get your stock heads ported, then get the PI instake, and install it using the intake spacers like the ones that are sold on Home and then get some PI cams, or supercharger cams and you should be good to go man.
If there's one thing in life you should never take for granted its the ability to drive fast when given the hp to. (PI engine swapped now, so i can go just a lil bit faster haha)
oh yeah, and why the hell do imports always try to race me?!
Old May 29th, 2009, 06:02 PM   #7
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
God for sure could get you a set. Maybe Jesus, but don't hold me to it.
MODS IN GARAGE
NCMM ORIGINAL
Old May 29th, 2009, 07:39 PM   #8
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
lmao.
well they came out with those new nPI heads that flow pretty well, and work with lower compression.
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
Old May 30th, 2009, 04:35 PM   #9
Boostang's Avatar
1997 Mustang GT
11.01@128.32
Boostang will become famous soon enough
Send a message via AIM to Boostang
ok just a thought but they say you cant run pi heads because it ups compression?
well im preety sure that there are some stock 99-04 stangs running superchargers.. and their compression is also 10.5 to 1!
as long as u stay below 450 to the crank ur safe..
If It Dont Flow It Wont Go!!!
forged pistons,teksid block and a romeo cast cranks for sale.. pm if interested..
selling them for next too nothing
Old May 30th, 2009, 04:40 PM   #10
1998 GT Mustang
N/A
4.6LMadness is on a distinguished road
whoa whoa, 99-04 have a smaller chamber because they have different pistons to keep compression down. its still in the 9 to whatever for the new edges. not no 10.5 to 1.
Pi Swapped, K&N CAI, Diablo Tune, BBk O/R X-Pipe with Flow's dumped and a 5.4L on its way.
Old May 30th, 2009, 04:42 PM   #11
Boostang's Avatar
1997 Mustang GT
11.01@128.32
ok my bad...
didnt know for sure just thought the heads and intake was the difference. didnt know they had diff peistons..
Old May 30th, 2009, 04:47 PM   #12
1998 GT Mustang
N/A
Boost + High compression = fail because it will cause the motor to detonate not blow apart because of horse power. You would have to run some pretty high octane to keep it from detonating with the supercharger. Or run super low boost. Like 6-7 psi.
Old May 30th, 2009, 05:59 PM   #13
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
i tried, they both told me to call santa......
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Threads Similar to: What is a guy to do????
theres this one guy zinc02GT The Clubhouse 34 July 20th, 2008 01:19 AM
New guy from NJ here.. DMC07GOGT New Members Introductions 18 June 11th, 2008 10:07 PM
Who wants to help this guy out? TurboLX 2005 - 2010 9 August 15th, 2007 04:49 PM
New guy here WVFord New Members Introductions 7 August 4th, 2007 11:51 PM
Just another new guy NotA35R New Members Introductions 2 July 23rd, 2007 10:45 PM
