noob looking for some expert knowledge
Old May 29th, 2009, 11:25 PM   #1
1997 mustang gt
busaonboost is on a distinguished road
Hey everyone I recently purchased a 97 mustang v6 with a 4.6 swap in it. From the looks of the car it was really taken care of but the previos owner couldnt tell me to much on what was done to it. Im not new to cars but just new to mustangs. So here are some of my questions....
1. I was told that it have a pi head swap in it. The oil fill is on the driver's side. Could that be possible. He said he looked at casting codes and they are pi heads but i dont know what he was talking about.
2. I know that the v6's came with a 7.5 rear end and the gts and cobras had a 8.8 rear. Its there any way to tell the differance between them ( diff cover bolts maybe)?
3. The car is and automatic and the speedo seems to be off a little. I was told that the car had differant rear end gears in it. How can i tell? my rear tires are 315-35-17 i dont think that would make much of a differance.
4 What kind of guage cluster did the v6 come with? my goes to 150mph
5. It also had a mach460 stereo what did that come factory in?
Sorry for all the small little questions but this is all info that i need to know or at least would like to know about the car. So if some of you mustang gurus out there can help me on this it will be much appreciated.
Old May 30th, 2009, 01:28 AM   #2
HorsepoweR's Avatar
99 SVT Cobra
N/A Yet
HorsepoweR is on a distinguished road
only thing i can say is if you have 3.73 gear in the rear it should be 10mph off and if you have 4.10 it would be 15mph off...
Mods iN Garage.:.919 of 4040.:.Born on 3/29/99
F
ound
On
Road
Dominating
Old May 30th, 2009, 01:40 AM   #3
Lind's Avatar
1994 Ford Mustang GT
Lind is on a distinguished road
v6 speedo- 120mph gt speedo - 150
mach 460 sound came stock feature on gt's
gears was already stated above about being off
and as far as heads go get the casting number of them and someone will be able to tell you for sure
www.moddedmustangs.com
Old May 30th, 2009, 03:32 AM   #4
1997 Mustang GT
97stanggt is on a distinguished road
Send a message via MSN to 97stanggt
pi heads depending if romeo or windsor depicts where the oil fill is windsor passenger romeo drivers in NPI engines atleast PI engines might be all the same but he could have used NPI valve covers on PI heads easiest thing to do if you cant get the cast numbers is pull the intake off the gaskets are all reusuable NPI heads have oval ports whereas pI have squarish larger ports the same with PI intake. for speedo if you want to know what gears you have make a mark on tire and driveshaft and for 1 tire turn how ever many revolutions the drive shaft makes is your gears 3.73 turns or 4.1 turns = those gears.
speedo could also be off possibly because of the gt gauge cluster i just use my tom tom in my car to judge my speedo is about 7-8mph off at all speeds but its got a guage cluster overlay on it and im not so sure its not just wrong on that not the speedo itself and the guy who put it in screwed all the needles up one day ill rest them all ;x
____________________________________________
97 Stang GT 5sp 5.4L SOHC
96 F-250 Stroker -=-Modded-=-
08 Kawasaki Brute Force 7504x4I
Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts.
Old May 30th, 2009, 06:47 PM   #5
1997 mustang gt
thank you guys for all the info
Old June 1st, 2009, 02:52 PM   #6
1997 mustang gt
anyone else? i would like to know if i have a 7.5 or and 8.8 rear end
Threads Similar to: noob looking for some expert knowledge
a few question, need expert opinion stfudvs 5.0 Mustangs 13 January 29th, 2009 09:59 AM
need your expert knowledge... 03gtfirered 99-04 20 November 12th, 2008 04:29 PM
Expert help U joints =\ tehdwarvenn 5.0 Mustangs 11 May 7th, 2008 03:04 PM
Photoshop Expert Needed SoonerStang 2005 - 2010 4 February 11th, 2008 10:41 PM
i need some expert advice. any help will help s3c2n01 96-98 1 April 9th, 2007 10:55 PM
