broken timing chain guide
Recently a timing chain guide on my cobra broke. All together it cost around $1000 dollars worth of damage after replacing bent valves, timing chains, oil pump, etc. When i put it back together I used an updated guide that bolts in front of the oil pump at one end. I was wondering if anyone had had problems with broken guides or if they knew of any other upgrades a guy could do to the timing chain system. Any advice would be much appreciated.
Never seen any problems with the guides. But did have a guy with a 5.1 stroker have his buddy put the motor together and they forgot to tighten them and his motor went bye bye.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
My Stallion is Bigger!
Lose the chain and get a cam gear.
i work in a parts store and have never sold a guide for the 4.6. Ive sold tc sets and chains but thats it. pretty wierd thou
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
#5 | |
#6 | ||
I was just F-in around.
I kinda thought you might be thinking that, but i wasnt sure. haha, A DOHC motor is gear driven with a chain. A non-interference motor would be much better. I installed a belt drive on my old 5.0. That was kinda cool.
that would be a very interesting shaped gear
#9 | |
What motor does youre bronco motor have? Cause if it has a 302/351 than its the same exact set-up as the 4.6 sohc/dohc. Except the crank gear is much smaller, and the chain is longer?
302 351 broncos are ohv engines. not ohcs so he can use gears on his
![]() bronco timing 4.6 timing it looks slightly different to me. am i wrong?
5.o bko
I know what kinda set-up it uses. I was just saying, no matter what kinda motor you have its going to have a Crank gear, and a cam gear. Whether its conneted with a belt or chain. They are the same interference motors. One just uses a over head cam and the other uses over head valves.
#15 | |
sorry didnt understand what you were saying.
Its ok.
ps. i sent you a friends request on myspace.
i saw that was trying to figure out which one on here was you. i accepted and thats cool that there is so many on here and are very helpful. how long has this site been up btw?
btw how do you put your profile in for a link below your name
Threads Similar to: broken timing chain guide
| Stock timing chain question? | jam77 | 5.0 Mustangs | 8 | October 30th, 2007 11:04 AM |
| timing chain gear instalation | FoxHoss | 5.0 Mustangs | 4 | October 21st, 2007 12:05 AM |
| timing chain gear instalation height?? | FoxHoss | 99-04 | 0 | October 20th, 2007 11:54 PM |
| TIMING CHAIN REPLACEMENT | CRZCOBRA | Modular Mustangs | 1 | July 9th, 2007 05:49 PM |
| 4.6 V8 4v timing chain set-up | Mauriello Motorsport | 4V / SVT | 2 | May 25th, 2007 11:10 PM |
