1998 Mustang GT
Anyone put a Tremec 3650 in a 96-98 GT ?
I have been searching for some answers to a couple questions I have. I got a killer deal on a complete PI engine & TR3650 pkg. I am hearing the TR3650 trans mount holes are about 1" farther back on the crossmember. I don't want to hack & weld. Will a crossmember from an 03-04 gt bolt in place of the original one? My T-45 is a mechanical speedo, the TR3650 is electronic. How can I make this work? Is there some sort of conversion kit/ converter box? I hope to figure this sh** out, the swap is scheduled for 6/20. Thanks for any help.
1996 GT Convertible
13.88@100.71
You can try asking in the '99-'04 section. There's a little more traffic there, plus you are asking about a motor and tranny from their years. They wont mind.
![]() Mods: Katzkin Leather, MMR stage II heads w/PI cams, PI intake, Accufab 75mm TB & Plenum, CAI, Ram HDX clutch, Pacesetter LT's & X pipe, Pypes hi-flo cats, Flowmaster cat back,3.73 gears, Sct SF3 tuner, Mamba M2's |
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
easy fix is to pick up the motor if it is in fact a great deal, bolt your t45 to it and sell the Tremec for 600 and get some bolt on's for the new PI motor.
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
1994 Mustang 5.0
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
It will Fit.And there is a Way to convert it,94-04 chassis wise are the same.
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- Last edited by 330CubeGt; June 11th, 2009 at 01:45 AM. |
1998 Mustang GT
Thanks for the responses, been away for a bit.
1994 Mustang 5.0
1996 Mustang V6
Its Realy Not that hard.you can Swap out the Extention housing to use yours to solve your speedo issue other then that its pretty easy to swap over.Never done it but i have read about it, Cant be to hard i just did a 5 speed to auto swap and it was Easy...
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
I have a t3650 in my '98 gt. The crossmember needs moved back a little, that was it, and you need an extended range speedcal to make the electronic speedo work.
2004 Comp. Orange Mach 1. With more mods than I can list. 11.59 @ 120mph 1.71 60' on a 100 shot. |
8.72 @ 81.68 1/8 mile
Where do you get that Extended Range speedcal
1 of 829 made Bright Tangerine Orange 10Lb Vortech V2,CXRacing FMIC MHS Stage 2 Blower cams,39# Injectors PI Intake,Ported and Polished NPI Heads BBK Headers,78mm BBK Throttle Body Mac H Pipe,2.5 inch Flowmaster Exhaust ,373 Gears |
I bought mine from Dallas mustangs. American muscle sells them too. Just make sure you get the "Extended Range", not the original version.
#10 | |
another dahm ford
OR you can spend NOTHING pull your tail housing off with like 8 bolts. pull off one snap ring. pull off your old plastic gear from your t-45. then install it on new one. its FREE. takes prolly 30 minites to swap both and put back together...... if you need a write up ill make one. it can even be done with tranny still in car..
![]() 97' 3.8 to 4.6 swap all stock 67' mustang gt coupe 88' ranger, just a clean ass truck 48' jeep cj2 the work hogg |
#11 | |
I didn't realize that was possible. I already had a speedcal so I didn't spend anything.
The trans cross brace will need to be modified but it will go in. And like they said, the SpeedCal will work. (But not very well, lol.)
#13 | |
75% good 25% bad responses on the SpeedCal and about 1/3 of the people try to return them. (I Have a friend that works for THR.)
3650 is a better trans than the T45 no matter your personal experience. the parts are cheaper, changeable bell housing and it can be built better for cheaper. If someone is dead set on building up a T45 they better do it soon since Tremec doesn't make parts for them anymore and VERY soon, the first run production parts are going to be replaced with Japanese parts. |
I think both the t45 and the t3650 are trash. I don't think either one is particularly better than the other, as far as durability goes. The design of the 3650 might be better, but it's full of problems as well. Just my opinion.
Yeah, I understand that. And I agree that neither are GREAT Trans.
#17 | |
#18 | |
another dahm ford
another dahm ford
and as far as t-45 vs the other. tear the t-45 down and look at the parts. agiant the t-5 that came out of my 3.8 v6. the t-45 is tinny brittle compared to even the t-5 if you have the money. swap a t-56 in there not that hard
Look Ma! My First Post!
mmikeclass06 I just got a 98 mustang 4.6 with the tremac and would like to see that right up on the speedometer VSS. Did you ever make it?
Threads Similar to: Anyone put a Tremec 3650 in a 96-98 GT ?
| Tremec 3650 | tqualman | 2005 - 2010 | 8 | May 7th, 2009 08:41 PM |
| tremec 3650 or t-56?? | 1fststang | 99-04 | 12 | July 3rd, 2008 05:41 PM |
| Tremec 3650 In 96 GT | jm06 | 96-98 | 4 | November 18th, 2007 02:46 PM |
| F**in tremec 3650 | 2002GTblkonblk | 99-04 | 14 | July 10th, 2007 11:41 AM |
| Help with the Tremec TR 3650( PLEASE) | H82LOSE | 99-04 | 1 | July 1st, 2006 06:16 PM |
