ticking noise
Old June 12th, 2009, 06:19 PM   #1
xbballkid_x is on a distinguished road
ticking noise
i have a 96 mustang gt i just put performance coil packs on and new plug wires. after the engine is warm there is a ticking noise. i tried making the gap wider to a .065 but the noise is still there. when i take my foot off the gas the ticking goes away. could someone please help me
Old June 13th, 2009, 10:01 AM   #2
Antfo89's Avatar
1998 Mustang GT
n/a
Antfo89 is on a distinguished road
Send a message via AIM to Antfo89
I have a wierd noise also its the timing chain slop. When it idles it nicks the cover. notorious on our cars apparently.
" There are alot of things to think about, but nothing to worry about "
Old June 13th, 2009, 03:07 PM   #3
03 Mach 1 & 02 GT
2002 BLK GT will become famous soon enough
Send a message via AIM to 2002 BLK GT
So it didnt make that before? and it just happened after the wires? This could be the biggest problem,a piston hitting use an stethoscope put it on the valve covers if you hear it louder your problem is inside. Any mods to the car?
2003 Mach 1 Procharged 500rwhp club
Old June 14th, 2009, 12:24 AM   #4
"stethoscope put it on the valve covers if you hear it louder your problem is inside. Any mods to the car? "
i did that and it sounded normal no piston knocking
and to antfo89... the ticking noise is only during acceleration with the foot on the gas... if i take my foot off the ticking goes away... if i stop the car and let it idle it does not tick
Old June 14th, 2009, 12:39 AM   #5
03 Mach 1 & 02 GT
Check your exhaust for leaks, lift the car have some one rev it while you're down there....
Old June 14th, 2009, 01:57 AM   #6
1997 Mustang GT
97stanggt is on a distinguished road
Send a message via MSN to 97stanggt
Big daddys got the idea my car does it too after had taken the exhaust off for a throwout bearing repair im guessing the gasket on one side doesnt like to be used twice but i know thats where my tick comes from also could be from other coupling points of the exhaust or a small rusted through hole and at worst case scenario or however ya spell it. it could be the manifold gaskets bad on one side
____________________________________________
97 Stang GT 5sp 5.4L SOHC
96 F-250 Stroker -=-Modded-=-
08 Kawasaki Brute Force 7504x4I
Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts.
Old June 14th, 2009, 02:02 AM   #7
03 Mach 1 & 02 GT
Thanks lol^ that's what I tried to say, mine broke from the manifold where it connects to the y pipe and I just had it welded and worked.
OP try moving the manifold from under the car with your hand if it moves then its starting to break, they shouldnt move.
Old June 21st, 2009, 06:10 PM   #8
its not an exhaust leak the only time it ticks is when i am accelerating... doesnt tick when i let off gas or if im just idling.
Old June 21st, 2009, 07:22 PM   #9
1998 GT Mustang
N/A
4.6LMadness is on a distinguished road
Don't say it isn't an exhaust leak until you get under and check. never assume until you know and never rule out possibilities. my car has a small exhaust leak on the drivers side and it can only be heard under acceleration. You cant hear mine at idle either just so ya know.
Pi Swapped, K&N CAI, Diablo Tune, BBk O/R X-Pipe with Flow's dumped and a 5.4L on its way.
Old June 22nd, 2009, 03:47 PM   #10
ok i def. agree with you on dont assume anything especially with cars... one symptom could be a million different things... so i got under the car and checked for the exhaust leak and none were found... the other thing i checked was the spark plugs and the ring around the ceramic is funny colored... i just put the plugs in and took it for a test drive... they are like a yellowish color just on the ring thanks for all your replies on the subject this is driving me crazy.
Old June 22nd, 2009, 06:52 PM   #11
1998 GT Mustang
N/A
Car might be detonating? Is it tuned?
Old June 22nd, 2009, 06:55 PM   #12
(sigh) thats kinda what i was thinking cuz ive checked all the plug gaps, plugs are the right heat range, and i just recently tried cleaning the MAF but its still doing it so im just gonna bring it to the dealer 2morro morning and have them take care of it.
Old June 22nd, 2009, 06:57 PM   #13
1998 GT Mustang
N/A
How long have you had your car?
Old June 22nd, 2009, 08:33 PM   #14
about 2 years now and it has 61000 miles
Old June 22nd, 2009, 08:34 PM   #15
1998 GT Mustang
N/A
Any recent mods?
Old June 22nd, 2009, 08:46 PM   #16
373 gears, cold air intake, steeda tri-ax, exhaust, and then the most recent coil packs i put on but i went back to stock because right after those it started making the noise
Old June 22nd, 2009, 08:48 PM   #17
1998 GT Mustang
N/A
Did you check all connections before and after the install? Make sure no wires were all fuckard up?
Old June 22nd, 2009, 10:27 PM   #18
Bearer of Bad News
Fluffy The Rhino's Avatar
I has mustang and legacy.
Slower than my Ruger.
Fluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to behold
Sounds to me either like an exhaust leak or the oh so glorious head tick
~MOD NUTSWINGER~
My Tongue Soothes Razorburn
STOPSAYINGFAIL.COM
EVERY FART IS A GAMBLE
Just Think Of Me As A White Blood Cell.
Old June 23rd, 2009, 03:37 AM   #19
1998 GT Mustang
N/A
i don't think its the head tick, my car has that and that shit is noticeable at idle.
Old June 23rd, 2009, 07:59 PM   #20
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
To check for a Exhaust leak Start up the car have some one hold a baled up rag over the tail pipes and if any exhaust leak you will hear it while laying under the car,Do a cold start so once you hear the leak you have time to put your hand on the pipe and feel where its coming from befor it gets to hot.
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Threads Similar to: ticking noise
ticking noise... Chris951 5.0 Mustangs 4 February 7th, 2009 01:42 PM
a ticking noise 87gtmustang 5.0 Mustangs 2 February 4th, 2009 03:27 PM
Ticking noise cbasmas 99-04 33 October 13th, 2008 03:46 PM
Ticking Noise? 99Rumblebee V6 Mustangs 3 September 27th, 2008 12:08 AM
ticking noise tweeters97 96-98 2 March 16th, 2008 09:31 PM
