Rollin' 18/ pushin' 2
differential question.
A guy here on craigslist has a built rear end for sale. he says it has a " spooling differentail" . I am not sure what that means. When I ask is it a limited slip or lokr he just keeps saying it's a " spooling". WTF DOES THAT MEAN???
It's got 31 spline axles/ differential and 4.10 gears with a stud kit and girdle.
A spool limits differential rotation to exactly zero. A spool consists of a pinion & ring gear only, the center is solid, the axle is one piece. A mini-spool is similar, replacing the usual differential center with a solid piece, retaining the factory axles. A spool is not a differential at all, but is used to achieve a similar effect to an LSD on some street and race cars.
Differential Full & Mini Spools Spools are a solid link for both axles. Lockers are ratchet style with teeth that still allow corner turning on the street without damage to axles. Lockers are about the next best thing to a spool. |
yeah, its for the track.. i WOULD NOT recommend getting that for a street car.
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
Thanks for the info guys.
No problem...
1994 Ford Mustang GT
street car your going to want a t-lock with clutches, that allow slip for cornering
www.moddedmustangs.com |
1997 Mustang GT
Faster than an s4
That or a true Limited slip. A true limited slip is better for cornering than traction lock. The traction lock does not have the smooth transfers for cornering that the limited slip does. Its a small difference, but it is there.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
Threads Similar to: differential question.
| Differential question? | TimboStang | 2005 - 2010 | 5 | November 17th, 2008 11:42 PM |
| Looking for a new differential!! | 1997Stang | 96-98 | 3 | September 12th, 2008 07:36 PM |
| Noob Question:What kind of differential do i have | 01 GT | 99-04 | 1 | May 28th, 2008 02:14 PM |
| rear differential question | rx1_ns | 96-98 | 3 | July 28th, 2007 03:09 AM |
| Differential | whitb610 | 99-04 | 5 | November 4th, 2006 10:49 AM |
