clutch compatibility question
Old June 14th, 2009, 01:53 AM   #1
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
ndfrspd is infamous around these parts
will a clutch from a 96-98 cobra fit a 98GT? this guy says his clutch came from his "96-98 cobra and its a 10.4-inch, 10-spline clutch disc and pressure plate. (Stock size and stock spline number for 96 to 98 Cobras) I recently upgraded to an 11-inch 26-spline clutch when I replaced my T-45 transmission with a Tremec TKO 600."
is that a bunch of bs or is it true cause i thought they were all 10.5 inch discs.
will this clutch from the cobra fit my 98 GT?
"The only way to learn about a car truly is to break something and fix it yourself..."
Old June 14th, 2009, 10:44 AM   #2
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I thought the cobras came with 11" clutches. You would probably get a better answer for this in the 4 valve section.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Threads Similar to: clutch compatibility question
X-pipe compatibility question Jobra 99-04 15 March 3rd, 2009 07:55 PM
What is this value and compatibility? INSTALLER020 5.0 Mustangs 14 September 13th, 2008 06:32 PM
Header compatibility datsundave3 94-95 2 July 21st, 2008 02:06 PM
S/C Compatibility... G.T. Rags 99-04 11 December 15th, 2007 12:35 AM
Gear Compatibility 04 And 05? R3dFyre02 2005 - 2010 8 November 19th, 2007 06:54 AM
