1997 Mustang GT
335rwhp/370rwtq
Valve spring compressor
What valve spring compressor do i need for Pi heads? the one i have doesnt work. Do i need a lever type?
1989 LX Coupe
7.1@99mph
OTC 7928
OTC Tools 7928 - OTC Ford Valve Spring Compressors – SummitRacing.com You can prob get it cheaper some place it. But this is what you need. If the heads are off the motor, any machine shop can do it and it will be way faster and probably cheaper than buying the tool if you only plan on doing it once.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
doesnt autozone have them, ill see if i can get a part #
1999 Mustang Cobra (rebuilding, someday...) 1996 civic dd [/SIZE] ![]() MM Cobra Club #3 |
1989 LX Coupe
7.1@99mph
IDk if they do or not. Never Checked there. They sell some generic ones that don't work...but I have never seen the OTC tools there.
2001 GT
![]() iTrader: 1 reviews
advanced sells them for a 100.00 I am doing a pi swap on my sons 98 right now along with Hitech stage 2 cams and manley springs.
03 Mach 1 full eaton swap, 18" chrome bullitts, H&R springs, 5.0 shifter, slp2, mac catted H, FRP 4.10's,443 RWHP/ 386 TQ |
1997 Mustang GT
335rwhp/370rwtq
Heres what i did. i used the compressor that you can rent from advance auto parts that looks like a C clamp. Since its not made to go deep enough into the head i took a deepwell socket and cut a 1inch wide/tall slit in it, starting from the open end, so i could slide a magnet through to remove the keepers. it was basically my extention!
Threads Similar to: Valve spring compressor
| Emergency/Parking Brake Spring Compressor? | Garhfer | 99-04 | 9 | August 29th, 2011 12:10 AM |
| Valve Spring Kit?? | BoostHard1210 | 99-04 | 11 | February 12th, 2009 09:19 AM |
| Do i need a spring compressor? | 98stangv6 | V6 Mustangs | 15 | October 13th, 2008 04:42 PM |
| Spring compressor tool | Jojogunne | 5.0 Mustangs | 4 | September 7th, 2008 11:56 AM |
