Super Spud
2002 Camaro SS
Port and Polish
Anyone got a rough idea about how much a port and polish job would be on a set of 97 gt nPI heads? Thinkin bout doing stage 2 cams and Ported & Polished heads + intake. Should yeild good numbers right?....
1997 Mustang GT
not as slow... PI swapped :-)
the numbers should be nice esp with the pi intake haha
If there's one thing in life you should never take for granted its the ability to drive fast when given the hp to. (PI engine swapped now, so i can go just a lil bit faster haha)oh yeah, and why the hell do imports always try to race me?! |
Super Spud
2002 Camaro SS
Im not worried about numbers too much. Mostly trying to get an idea on price so I can budget my whole build. I wana get the best bang for my buck.
Granny Shifter
NPI can run pretty quick, but it was so much easier to make power with a set of PI Heads. I had a 9:1 NPI in my car, ported npi heads, comp xe274's, and long tubes, made 219 rwhp. On the PI motor, ported the heads, same 9:1, same cams, same long tubes, added a dragon upper intake and accufab 75mm tb, and it made 299hp. So between the heads, the intake manifold, the upper intake manifold, and the throttle body it picked up 80hp at peak. Went from a 14.6 npi, to 13.5 pi both at bandimere speedway. If budget allows, might look into a set of PI's, we've found them anywhere from free to $300 a set, used.
Super Spud
2002 Camaro SS
You only picked up 20 hp porting your nPi heads??? Thats just dissappointing..... How much did the port job run you?
Granny Shifter
I did both sets of heads myself, just my time and a die grinder, made em bigger and similar. I never did a baseline pull, I think matt made a little over 180 on his, up here, but I couldnt tell you what the gains were from stock, but with the lowered compression and those mods, thats what i made at 5280 feet above sea level. It was corrected, but who knows how accurate any of this dyno business is. The cams and the ported npi heads took me from a 15.2 to a 14.6, and the PI heads, upper intake plenum and throttle body took me from 14.6 to 13.5.
But if you are really going to make any power N/A with these engines, you need to have PI heads..
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
1997 SVT COBRA
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
Port Matching is nice because it frees up some power and it dont cost you anything but your time so its good to do but you will deff see larger gains if you have a pro do them and put them on a flow bench and do it the Right way.Just my 2 Cents.
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
Super Spud
2002 Camaro SS
So, ported nPi heads vs pi heads. Which will you see more gains with an aftermarket cam like comp 270's?
1997 SVT COBRA
1996 Mustang V6
Ported PI's I mean come one Look at the Size of the intake Ports from a NPI to PI,More Flow More Power...
Super Spud
2002 Camaro SS
Yea i figured as much. Still dont know how much a port job will cost. haha. But Im probably gonna get the Pi heads and port them to run comp 270's
Granny Shifter
Yeah, heads done be a pro may take some variance out, especially with a flowbench, and yes Ported PI Heads will see a larger gain, for sure.
#13 | |
You failed to mention what intake you were using on the NPI setup. I can promise you that the MARKET put the hype on the PI heads. NPI head are very good contenders when set up correctly. It is proven that the NPI intake and NPI cams are the choke holds for the NPI heads. WITH STOCK NPI long block, only replacing PI intake and PI cams, their was only a 10hp diffrence between a stock PI longblock and Stock NPI long block wPI intake and PIcams. The PI was 10hp more. Here's the kicker The NPI heads have a major restiction around the valve called a swirl dam. This dam promotes in coming air to swirl and mix the gas better and keep it off the cylinder walls. Laying this dam back a little(not removing it) with a dremel(porting tool) improves low lift dramaticly!!!!!! I've done enough CrownVic and thunderbird reviews to claim the NPI, PI head war is BULLSH!T. Your NPI heads are awsome heads! Don't sell them short. Find a set, do some research, and port them yourself. It's easy! Results are great! |
Granny Shifter
PI Has a swirl dam also, and I never said a npi car couldn't be quick, we've taken one to the 11's up here. So, what did you do to get your npi to over 300whp on the motor?
Granny Shifter
Ran 14.9 with Ported NPI heads, NPI Intake Manifold and stock PI cams. Added comp xe274 cams, made 219whp with the npi intake manifold. Added PI Intake Manifold, ran 14.6
#16 | |
need tuned
![]() iTrader: 1 reviews
1 of 829 made Bright Tangerine Orange 10Lb Vortech V2,CXRacing FMIC MHS Stage 2 Blower cams,39# Injectors PI Intake,Ported and Polished NPI Heads BBK Headers,78mm BBK Throttle Body Mac H Pipe,2.5 inch Flowmaster Exhaust ,373 Gears |
Threads Similar to: Port and Polish
| windstar split port swap or port and polish | winnie51189 | V6 Mustangs | 22 | November 4th, 2008 04:04 PM |
| port and polish ? | armymike63b | 4V / SVT | 9 | September 4th, 2008 02:22 AM |
| port and polish | gQQgsJr | V6 Mustangs | 44 | August 13th, 2008 01:29 AM |
| port and polish | riddlee josh | V6 Mustangs | 36 | July 25th, 2008 10:13 PM |
| 99+ Port And Polish do it your self | Juggalo_X | V6 Mustangs | 2 | February 14th, 2007 01:49 PM |
