Need Post PI Swap Help/Opinions
Old June 20th, 2009, 05:49 PM   #1
rlisak is on a distinguished road
I just finished a PI swap. Car was a 98 GT and the heads and intake were from a 2003 with 12k miles. Romeo to Romeo swap.
Also added a 75 mm throttle body and Accufab upper plenum.
Post swap, the car hesitated and sputtered and gurgled on heavy acceleration... cruised fine... slow accel fine... 3kRPM+ accel ok but not great, heavy accel or dump the clutch ... horrible boggy mess.
Changed TPS.. voltage perfect.
Changed IAC. Idle is... eh... 800 or so and not great, but fairly steady.
No gas smell from exhaust.
I had an old Hypertech chip on the ECM and removed it, reset, no change.
Cleaned the EGR. No change
Cleaned the MAF sensor, no change.
No oil or coolant leaks.
'stomping' the throttle parked, with no load, revs respectably (not great IMO)... under load, it bogs and sputters and 'gurgles'.
Plug wires are new. plugs are new. Gap is checked and ok.
Checked wire to plug contact 100 times. Coil packs aren't new but are aftermarket and not too old (3 years)... ran fine befre PI swap.
Did the old 'starter fluid vacuum leak test.' All good.
Note that it runs better at higher RPMs, so I'm doubting timing, fuel pump, injector pressure. ie : stomping gas at higher RPMs responds better than at lower, so I'm assuming timing, fuel delivery, isn't the issue.
Alternator and batery test fine.
Oh.. and It's not throwing any codes! OBD says all is fine.. I even went out and layed on the gas to make it sputter for 15 minutes and then checked... no codes.
WHAT ELSE COULD POSSIBLY BE WRONG!!!?? * wah wah - whine *
Old June 20th, 2009, 05:51 PM   #2
Military98stang's Avatar
1998 GT VERT 5 SPEED
Military98stang will become famous soon enough
have you gotten it tuned yet. You def need to do that if you have not. That will make it go away most likely
http://www.cardomain.com/ride/3068325
EAT ...... SLEEP .......LIFT........repeat!
Old June 20th, 2009, 06:23 PM   #3
NMR-2vGT's Avatar
1996 GT
Too Slow....
NMR-2vGT will become famous soon enough
Send a message via AIM to NMR-2vGT Send a message via MSN to NMR-2vGT
You dont need a tune for a PI swap. My car runds fine without a tune. Any vacuum leaks? I would think you didnt get a sensor plugged all the way in as i had that problem with mine but then again you said it didnt throw any codes. And if it was a vacuum leak itd most likely be noticable at idle. But it sure wouldnt hurt to chec those out anyway.
1996 Mustang GT, Full PI Swap, MGW Shifter, Magnaflow Cat-back, K&N Filter
MM Unite For Bubba
Old June 20th, 2009, 06:24 PM   #4
1998 GT Mustang
N/A
4.6LMadness is on a distinguished road
The stock computer needs to go through some heat cycles before it will start running right. My car ran rich for about 2 weeks before it stopped freaking the fuck out. You will want a custom tune though because the stock PCM can only do so much with the stock tune.
Pi Swapped, K&N CAI, Diablo Tune, BBk O/R X-Pipe with Flow's dumped and a 5.4L on its way.
Old June 20th, 2009, 11:45 PM   #5
1997 Mustang GT
not as slow... PI swapped :-)
mustangracer2g is on a distinguished road
i got a pi engine in my car and i could tell that the computer had to readjust to the a/f ratio and all
If there's one thing in life you should never take for granted its the ability to drive fast when given the hp to. (PI engine swapped now, so i can go just a lil bit faster haha)
oh yeah, and why the hell do imports always try to race me?!
Old June 21st, 2009, 09:27 AM   #6
New symptom....
As of last night, after the new IAC the car now has an idle surge. Idle is adjusted at the TB to 800 and stays there if I unplug the IAC. Revs to 4000 when I plug it back in. My car has gone insane.
Fixed this... idle screw was loose and wiggled the throttle open... duh. I wish the rest of it was that easy.
Old June 21st, 2009, 10:01 AM   #7
Antfo89's Avatar
1998 Mustang GT
n/a
Antfo89 is on a distinguished road
Send a message via AIM to Antfo89
DUDE MINE TOO! My car is doing the exact same crap and I wanna take it out to the pasture! My car feels like it has a f350 pulling it in the opposite direction when I stomp on it.
" There are alot of things to think about, but nothing to worry about "
Threads Similar to: Need Post PI Swap Help/Opinions
thinking of doing a swap..need opinions Traidmarx 5.0 Mustangs 42 January 6th, 2010 10:29 PM
opinions about this look on my car...please vote....or post your opinions.. turbot4 99-04 79 July 22nd, 2009 07:31 AM
Opinions on a transmission swap. Blitz34 99-04 8 June 17th, 2009 01:06 AM
opinions (doing an engine swap!) joohnn98 96-98 5 May 9th, 2009 01:29 PM
Stick to Auto swap...opinions needed Diabeetus 4V / SVT 1 December 24th, 2008 06:50 PM
