Eaton M90 supercharger
Old June 21st, 2009, 09:21 PM   #1
1998 Mustang GT
13.046@107.49
cruizer will become famous soon enough
I have a 98 GT. I just bought the stuff for a PI swap, haven't installed yet, and I heard about putting the eaton m90 supercharger from a supercoupe on for big gains. I would like to use the PI heads and cams and get a different intake so the supercharger will fit. The PI heads will increase the compression to 10:1 but I was told there was a chunk of metal on the heads near the name tag or numbers or something??? that you can grind off to lower it to about 9.5:1. I was told this was just there for efficiency but if I go forced induction it won't matter to get rid of it. Has anybody heard of this? I could find out more information about it if necessary. I was also told I would be able to run 6 to 7 lbs of boost on the stock internals with no problems.
My main question is what intake manifold to use. I know this is usually just done to the v6's but I've found several references to doing it on the GTs, but not enough information. I've heard that you could use a saleen or roush intake manifold and it would bolt right up and still fit under the hood. Supposedly the saleen intake manifold is a little more restrictive so you don't get as much power. My question is where would you even find these, if there are other intake manifolds you can use, and if anybody can confirm this information? Also there is an Allen kit that runs about 4k that uses the m90 but you can buy a m90 off ebay for between 200 and 400 and if I could find the intake, I think I can get it all for under 1k. Also does anybody know of any other parts I would need? just a throttle body maybe???
Old June 21st, 2009, 09:28 PM   #2
Drtbkercr5's Avatar
Just looking...
Drtbkercr5 will become famous soon enough
I always wondered about this...this should be interesting. Im not sure at all.
1997 Mustang GT SOLD
2004 Pontiac GTO SOLD
Torrid Red with Red Leather Interior
1 of 571 made.
Originally Posted by Drgnracin72 View Post
ive seen 2 boys fucking and ive seen roll racing, and roll racing is definitely gayer
Old June 21st, 2009, 09:53 PM   #3
fsttang96's Avatar
need tuned
fsttang96 is on a distinguished road
I was told that just by grinding that off it will increase the cc's in the heads only by 2cc's making the PI heads 45 cc's I dont think it will be enough to drop the compression down to 9.5:1 I heard it only drops it down .2 ! The stock NPI heads are 52 cc's and I think the stock compression on the NPI motors is 9.3:1 !! I was going to put PI heads on mine and most everyone I talked to said that they would NOT put Pi heads on and run a Supercharger without putting in different pistons !
1 of 829 made Bright Tangerine Orange
10Lb Vortech V2,CXRacing FMIC
MHS Stage 2 Blower cams,39# Injectors
PI Intake,Ported and Polished NPI Heads
BBK Headers,78mm BBK Throttle Body
Mac H Pipe,2.5 inch Flowmaster Exhaust ,373 Gears
Old June 21st, 2009, 09:58 PM   #4
Redux's Avatar
1998 Mustang 3.8
Redux has a spectacular aura aboutRedux has a spectacular aura about
iTrader: 6 reviews
I have a, as close to, full kit for sale right now. All you would need to buy after the kit would be a fuel pump, and timing cover. I have everything else, fuel injectors, alt., belts, intake, etc...
http://www.moddedmustangs.com/forums...arger-kit.html
Vote for Reps!
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you make it through the wall.
Old June 21st, 2009, 11:26 PM   #5
Redux's Avatar
1998 Mustang 3.8
iTrader: 6 reviews
And by kit I meant for a V6.
Vote for Reps!
Old June 21st, 2009, 11:31 PM   #6
1998 Mustang GT
13.046@107.49
I'm looking for a v8. And yeah that's why I waited and haven't put on the pi heads yet. But I have to wonder that the 99 - 04 guys put superchargers on their mustangs right? How do they do it? Is it not on a stock head or do they have to go with forged internals to supercharge? A thicker head gasket would only lower the compression by about .1 would it. Would it be worth it because you blow the thicker head gaskets easier right?
Old June 22nd, 2009, 12:35 AM   #7
fsttang96's Avatar
need tuned
The 99 -04 mustangs have a dish type piston which with the smaller combustion chambers on the head bring there compression down to ( I think ) 9.5 or so. On 96 - 98 they had what they call a flat top piston that is why the compression goes up to 10.1 when putting on the PI heads! There are ways to get around the compression thing like thicker gaskets but its to my understanding that if you drive the car alot and want it to be reliable and not air condition the block it not a good idea unless you spend some money and do it right by changing the pistons
Old June 22nd, 2009, 01:48 AM   #8
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
Look for a 99-04 Saleen Lower The blown Saleens Came with M90's.
Seen a Damn Near complete Setup on Ebay about a month ago.
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old June 22nd, 2009, 02:33 AM   #9
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
ndfrspd is infamous around these parts
v6 is for pussies.
"The only way to learn about a car truly is to break something and fix it yourself..."
Old June 22nd, 2009, 09:33 AM   #10
Drtbkercr5's Avatar
Just looking...
What if you didnt want to switch to PI Heads? Would you look for a 96-98 Saleen lower? Or is that just not possible?
1 of 571 made.
Old June 22nd, 2009, 02:47 PM   #11
MikeD05GT's Avatar
2005 Mustang GT
MikeD05GT will become famous soon enoughMikeD05GT will become famous soon enough
Send a message via AIM to MikeD05GT
Originally Posted by ndfrspd View Post
v6 is for pussies.
thanks for the wonderful advice jackass...
ive always heard that the m90 swap is more trouble than it is worth...
not saying not to try it..or that that is my opinion...but if you can find all the stuff for cheap...go ahead!!
Old June 22nd, 2009, 02:58 PM   #12
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
The supercharged 96-98 Saleens used centri's, They didn't start using a roots type until 99.
Ford Motorsport SVO did make a roots type blower for the 96-98 npi motor. They are VERY hard to find but can usually be picked up used for less than 2k. Iv'e been looking for one for a couple years now and have only come across three. Only 2 of those were for sale and one of those required you to buy the complete engine to get it.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old June 22nd, 2009, 03:30 PM   #13
1998 Mustang GT
13.046@107.49
The Allen kit claims 100+ hp increase on only 6psi and they use a m90. So in my opinion that's good enough gains for the trouble especially when if I can find an intake I think I can get all the parts off of ebay for under 1k compared to all the other supercharger kits that are upwards of 4k
Here is the link for the allen kit: Allen Supercharger Kit w/Integrated Intercooler for 1998 Ford Mustang GT w/4.6L (6psi)
Old June 22nd, 2009, 05:35 PM   #14
Drtbkercr5's Avatar
Just looking...
Thanks for the good info. I dont have the time nor patience to sit and look for an SVO blower. lol
1 of 571 made.
Old June 22nd, 2009, 11:06 PM   #15
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
iTrader: 14 reviews
The guys car went 13.8. with a M90.My Car was 13.8s all day With a stock N/A 4.6 With Gears,CAI,M/Ts
If i Did not go atleast 12s With Some Sort of Power Adder i would be disappointed.
Old June 23rd, 2009, 09:53 AM   #16
MikeD05GT's Avatar
2005 Mustang GT
+1 i feel the same exact way
Old June 23rd, 2009, 07:49 PM   #17
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
iTrader: 14 reviews
I know a guy that has a Saleen Vert i belive its a 00.He hates the M90 on his hes pushing 12PSI and i have seen him get beat by a stock 350Z and a 00Gt with Exhaust.Car Looks Sexy as hell and soungs great but he seems to be disappointed with it and wants to make it faster but the M90 is not enuff.
Threads Similar to: Eaton M90 supercharger
Eaton M90 gkizzle3622 V6 Mustangs 8 November 12th, 2007 07:37 AM
Eaton M90 Supercharger 2002stang V6 Mustangs 4 October 10th, 2007 04:05 PM
Eaton m90 supercoupe supercharger..... 99v6stang V6 Mustangs 3 May 16th, 2007 11:20 PM
Eaton M90 Cricket V6 Mustangs 10 September 14th, 2006 11:58 PM
