1996-1998 mustang gt power - Page 2
LinkBack (1) Thread Tools
Old July 7th, 2009, 05:46 PM   #21
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
I would not stay withe NPI heads. Ported NPI heads put out numbers about the same as PI heads and Porting costs alot more than getting a set of used PI heads. The better flow and potential of the PI head greately out weighs the power and flow of the NPI especially when adding boost or Nitrous to the equation. As the power increases, that difference in efficiency gets bigger and bigger.
AS far as potential goes, there are people that have gotten these motors to over 400hp NA, but it costs alot of money and is not streetable.
Beating your friends car is going to take...
swap to some PI heads ($300)
Swap to Stage 2 Cams. ($500)
4.10 gears ($300)
Get more serious...
Vortech Super Charger kit ($3000)
End result, about 360-400 rwhp with a 1/4 mile in the 12's if you know how to drive and strip it down a little bit.
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old July 7th, 2009, 07:17 PM   #22
the misfit wolfie's Avatar
faster than the stealth
the misfit wolfie is on a distinguished road
Originally Posted by GMoney98 View Post
Those are the mods I have done except i didn't p/p my heads and they are pi. Once i get eveything done i will post a video for you to see if thats what you want to do.
sweet. id like to see it, i was playing with different ideas and dont know quite which way to go.
i agree that you would see the same, if not more with the pi heads, but you would also be raising the compression ratio and that wouldnt be too good if you want to boost later on, sticking with ported npi heads just leaves you open for more options. but if he has no desire at all to boost or put nitrous in his car without working on the bottom end, then go for the pi heads.
1996 Mustang GT 5-speed
sold..
http://www.youtube.com/watch?v=5VuRDQGk4k8
http://www.cardomain.com/ride/3340297
Old July 7th, 2009, 09:01 PM   #23
1998 GT Mustang
N/A
4.6LMadness is on a distinguished road
You can safely run nitrous on a high compression motor. It doesn't bump your static compression ratio like boost does. You just need to retard the timing a bit and maintain proper full mixture to avoid detonation and your good to go.
Pi Swapped, K&N CAI, Diablo Tune, BBk O/R X-Pipe with Flow's dumped and a 5.4L on its way.
Old July 8th, 2009, 02:21 AM   #24
1997 Mustang GT
97stanggt is on a distinguished road
Send a message via MSN to 97stanggt
5.4 with just stage 2 cams will run you 300hp about 330tq at the wheels... and alot more torque down low ied say a 5.4 swap spend 5k on it and forge the bottom end with some deeper dish pistons to keep compression low and then spend another 3000-4000 later on for a blower and put down some serious numbers and leave ur friend wanting more also ;> but unless he goes 5.4 also hell never keep up without some serious work
____________________________________________
97 Stang GT 5sp 5.4L SOHC
96 F-250 Stroker -=-Modded-=-
08 Kawasaki Brute Force 7504x4I
Selling PI Cams/NPI intake Alum Cross/4.6L LongBLock minus Oil pan and most of the timing cover bolts.
Old July 8th, 2009, 02:43 PM   #25
1998 mustang gt
mister0big is on a distinguished road
Send a message via AIM to mister0big
hell ya that sounds good g money. ok here are my new questions
how much can i get a 5.4 for, does it have a forged block already?
if i rebuild my engine, should i keep any factory parts, and what are your recommendations for a block for the 4.6? and can it handle a supercharger if i put one on later? i dont think im going to put nitrous on it just a supercharger.
98 GT, Cold Air Intake, Flowmasters, off road H-pipe, Predator Tuner, MIL Eliminators, BBK 70mm Throttle Body, Stack upper intake, plenum Spacer, t2 rear dif, moser axles, ford racing aluminum driveshaft, 4.10's, steeda tri axe short throw shifter
Old July 8th, 2009, 03:33 PM   #26
for the engine it varies, some people here have gotten it for under 500, iv seen them for over 1000. go to car-parts.com you can look for the engine there. and if you rebuild your 4.6, it all depends what your going to do to it. stock, the engine can handle up to 9 or 10lbs of boost, which is still a fair amount of power. if your going to get block, forged is always good. expensive though.
or you could go with this, although its most likely over 5k,
Recipe for a 350 RWHP NA 2V
sold..
Old July 8th, 2009, 03:42 PM   #27
1997 Mustang GT
Faster than an s4
So far, money wise, i have not seen the 5.4 make up the difference. Its a pain to get in the car and hooked up correctly, and with no good aftermarket headers. And no really well flowing 2v heads. The displacement difference is good, but not as good as it could be. I see lots of people with really nice set ups not putting down a real worth while difference.
Of course, I'm sure if you take the time to do it right, its worth it, and more power is definitely more power. I just don't think its worth the hassel, atleast not with a 2v motor.
As far as the forging goes, if you know how to wrench, you could do it your self for 1500 dollars and have a motor that is good to 700 hp. Throw a $4k super charger kit at it, and your at 500 rwhp easy. Now at that power level, you need some supporting mods in the rear end and some suspension. But with that much power, your basically a race car anyway.
I really think pointing him to the 5.4 swap is like pointing him at an 03-04 cobra engine, no doubt its cool, but its way to large an undertaking for his experience with this car, and the money he is talking about. Remember the golden rule. It always costs 50-100% more than you expect.
BTW, proper porting will help reduce how much the compression ratio goes up.
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
04' PI Motor
Old July 8th, 2009, 03:58 PM   #28
1997 Mustang GT
umm to get it in all i did was ground a nub off the pass side exhaust manifold.... and then 30min to get it on hoist in car and engine mounts bolted down....hows that hard? and about 1 1/2 hrs hooking back up ps pump ac pump accessories motor in to motor running was probaly 4 hrs work since i broke the oil filter adapter thats it ;> so whoever told u or if u think its hard to get in is idiotic in all sense of the word or is the worlds shittiest mechanic
Old July 9th, 2009, 04:01 PM   #29
1998 mustang gt
for 1500? how can that be done? i am pretty interested now as i only want to acheive 500-600 hp with a supercharger. is this what you have done to your mustang?
and also thanks everyone for the knowledge.
Old July 9th, 2009, 04:10 PM   #30
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
Realistically,$1500 for forged internals is if you build it YOURSELF as stated (If you know how to wrench) so don't expect any less if your going to have someone build it for you... it can be done, but it will probably be more than that if you don't know how to build it.
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
Old July 10th, 2009, 05:00 AM   #31
Genibus Nitito Canus
HBK_2007's Avatar
2009 Ford Mustang GT
next year
HBK_2007 will become famous soon enough
Send a message via MSN to HBK_2007
i could prolly rebulid a 4.6 block for 1500 but...by myself i wouldnt trust my handywork so id have to have someone (prolly my dad) help me so it would cost a bit more. i think mmr is having a sale on short blocks.
as for a 5.4 goes. if u have the motor already (or get a stupidly cheap deal on it) i wouldnt run it due to the fact u can get the same results hp wise and be that much lighter (lighter is faster, hp being the same) and i havent seen a 2v 5.4 thats been able to make up the difference in wieght in tq vs a alumium 2v 4.6.
Ford Racing Performance Parts [M-6010-GTWS*]
that bitch is a totally different story tho. if it didnt cost $4K id have one in a second and that would be the only way to go
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about
Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, muffler delete
Old July 10th, 2009, 03:31 PM   #32
1998 mustang gt
thanks again. my uncle has been a mechanic for 20 years he said he will help me rebuild it(meaning he does the work i watch and buy the beers) lol. so i am interested in the 1500 idea, what parts would that be, i have been looking at blocks but am unsure of were to buy online.
Old July 10th, 2009, 03:36 PM   #33
1993 mustang GT
50fanatic is on a distinguished road
So with the PI top end, the 96-98 4.6 mustangs or 94-96 4.6 thunderbirds will make more power than the 1999-2004 mustangs?
Old July 10th, 2009, 04:06 PM   #34
1999 Mustang GT
Regulator is on a distinguished road
Send a message via AIM to Regulator Send a message via Yahoo to Regulator
Correct, as the pistons they have along with the PI head yields a higher compression ratio
'99 GT FS/FT. Click here for details!
"And I heard a voice in the midst of the four beasts, I looked and behold: a pale horse.
And his name, that sat on him, was Death. And Hell followed with him."
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/129139-1996-1998-mustang-gt-power.html
1998 Mustang Gt and Horsepower on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback July 21st, 2009 01:38 AM
Threads Similar to: 1996-1998 mustang gt power
Your 1996-1998 Mustang Bible & How-To Info Center TheUNZippee! 96-98 22 September 6th, 2010 10:45 PM
1996-1998 cobra intake and throttle body 969800gt 96-98 4 April 17th, 2007 02:14 PM
1996-1998 cobra ih8chevy Modular Mustangs 9 December 10th, 2006 05:16 PM
Which Is A Better Motor The 1994-1995 5.0 Or 1996-1998 4.6 Darren 5.0 Mustangs 8 October 12th, 2006 10:41 PM
