Port non p.i. Intake runners to match p.i. Intake
Would yall suggest this. I can do the porting myself so it wouldnt cost anything but i dont wanna go screwing a set of heads up if this cant be done. Do the non p.i. Heads have enough material on them to do it. Has any of you done it?
8.72 @ 81.68 1/8 mile
I am interested in hearing the answer to this myself because I plan on doing the same thing this winter !!!
1 of 829 made Bright Tangerine Orange 10Lb Vortech V2,CXRacing FMIC MHS Stage 2 Blower cams,39# Injectors PI Intake,Ported and Polished NPI Heads BBK Headers,78mm BBK Throttle Body Mac H Pipe,2.5 inch Flowmaster Exhaust ,373 Gears |
Rollin' 18/ pushin' 2
There is one way to find out. If you do it successfully you may have just made yourself rich.
Ive never heard of it being done but if all ford did was take non p.i. Heads and modify them then with some time and work i should be able to do it. But i ve never had a chance to look at p.i. Heads up close to tell any differences. I dont like the idea of using those adapters. All they do is smooth the airflow between the p.i. Intake and non p.i. Head.
There is not enough material to match them. By doing so you would probably end up losing power in the long run by causing turbulence in the ports and disrupting the airflow. Ford did not just modify the NPI heads they were a total change in design. Bolt on the PI intake and be done. You cannot just take a grinder to heads and make power, there is a lot of science to it. Most that try to port their own heads make them worse than they were when they started hacking on them.
The mismatch is not enough to cause a restriction to matter. You don't need to use the adapters you can bolt it on and use a little rtv without any issues. Believe it or not NASCAR engine builders have used a mismatch on port alignments on restrictor plate engines to increase power.
No you can't do it and it wouldn't make sense to try; It's the runner design that is what looses the 15hp not the ports.
Ok cool that answers it for me. Is there anything you guys would suggest to squeeze a little power out of the 97 heads
No. You can have them ported to flow the same numbers as a ported PI head but then you're still stuck with the limited NPI intake. Your best bet is a PI engine swap, 4v swap or the PI H/C/I swap.
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
another dahm ford
you can match then. i matched my bullitt intake to my non pi engine. there is not really a lot of difference in size, unlike what a lot of people make it out to be
![]() 97' 3.8 to 4.6 swap all stock 67' mustang gt coupe 88' ranger, just a clean ass truck 48' jeep cj2 the work hogg |
See this morning a guy at the ford dealership told me he heard of a couple guys doing it. He said just to make sure i keep the shape the same. And i remember a while back at the race track a guys intake cracked and i was watching him take it off to fix it and his intake runners where massive. Now he said they where npi heads but i never asked if they where aftermarket.
if the ports looked like PI, then you would use a PI Manifold right?
1997 GT 1989 LX ~Dangerously Quick/Needs Battery
Threads Similar to: Port non p.i. Intake runners to match p.i. Intake
| VAP Single Port Intake Spacer Kit | Assassin_Dan | V6 Mustangs | 5 | July 9th, 2009 11:04 PM |
| what years did mountaineers have EGR port in the intake??? | cobtc | 5.0 Mustangs | 1 | May 6th, 2009 12:50 AM |
| Can i port and polish my upper intake plenum??... | 99spaded | 99-04 | 6 | July 30th, 2007 07:41 PM |
| port and polish intake manifold and throttle body.... | camer | V6 Mustangs | 2 | May 10th, 2007 12:08 AM |
