A/c Problems
Old July 24th, 2009, 12:26 PM   #1
roquecampos is on a distinguished road
A/c Problems
The a/c in my 97 v6 only comes out of the defrost vents. I changed the function selector switch, still doing the same.
Old July 24th, 2009, 01:31 PM   #2
Trick Tuners's Avatar
KB'd GT
I think these are vacuum powered. check the vac line that comes thru the firewall to make sure its connected to the vacuum system. If it is, and has vacuum (you can 'suck" on the hose if you don't have a gauge to make sure its pulling vacuum) then pull the AC knob thing and make sure its connected and getting vacuum to the back of it. I'm not 100% on the mustang ac operation, but my jeep did the exact same thing and it was a cracked fitting near the engine that leaked my vacuum signal.
Old July 24th, 2009, 05:48 PM   #3
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Shrink tubing is all you need to jimmy that up.There is a small vacume line on your upper plenum between your IAC and your TB position sensor. This vacume line controls the levers in your vent system. When one of them breaks it will only work on defrost. I have posted some pics for you. The lines are red, and on one of the pics you can see the white shrink tubing covering mine where it was cracked.
A/c Problems-hpim2494.jpg   A/c Problems-hpim2495.jpg
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old July 24th, 2009, 05:55 PM   #4
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
what he said....
TT Build in progress.......
Old July 24th, 2009, 06:03 PM   #5
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I see that was your first post, btw.
Welcome to the forums.
MODS IN GARAGE
NCMM ORIGINAL
Old August 17th, 2010, 04:48 AM   #6
kiko is on a distinguished road
Hi, I just face to this problem today.
Do you still have those reference pictures?
Thanks in advance!
Old August 17th, 2010, 08:11 PM   #7
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
replaced my intake manifold broke some vacuum lines help?
There is a pic already posted in the above thread, Check it out and maybe it will help you out.
MODS IN GARAGE
NCMM ORIGINAL
Old August 19th, 2010, 07:11 AM   #8
Thanks for the link, 97S281.
I'll check my cable tomorrow. Hope it won't be too bad so can handle by newbie like me!
Threads Similar to: A/c Problems
5.0 Problems Monk 5.0 Mustangs 0 August 31st, 2008 09:37 PM
Problems adrenaline=lifeline 99-04 3 August 25th, 2008 04:20 PM
A/C problems HOLLYWD69 Mustang II 7 July 6th, 2008 02:42 PM
Problems 98blackonblack V6 Mustangs 1 January 2nd, 2008 02:51 AM
more problems ks_emt 2.3 Mustangs 7 June 7th, 2007 03:16 PM
