Need oxygen sensor help
Old August 12th, 2009, 11:14 PM   #1
86ttops's Avatar
86,97 mustang gt t tops
n/a
86ttops will become famous soon enough
Send a message via Yahoo to 86ttops
I Have been having problems on and off for a week now. My 97 gt sohc 4.6 will idle real rough and when you are cruising at one speed it cuts in and out. I thought i had bad gas but it does it off and on nothing seems to trigger it. I put 500 miles on it this weekend and no problems but it is back at it again today. Today the check engine light came on so i scanned it and it came up bank 1 sensor 1 lean. From what i gather that is a oxygen sensor bad?? If so which one would it be? I assume a front one it has 4. I was thinking of doing a tune up and getting some of those g3 plugs are they worth it?
Old August 12th, 2009, 11:24 PM   #2
1998 mustang gt vert
98stanger is on a distinguished road
Send a message via AIM to 98stanger Send a message via Yahoo to 98stanger
truth be told. only buy ford parts. aftermarket stuff sucks. go with motorcraft or ngk plugs and ford racing wires. butthe 02s from ford. there 130 a piece but worth it and replace both of them. oh yeaaaa do u have long tubes
check out my garage for info
Old August 12th, 2009, 11:39 PM   #3
86ttops's Avatar
n/a
It already has ford racing wires on it. i think the guy i bought it from ( did not seem to be to smart) changed the wires because he wanted blue ones to match the cold air intake. I don't think he changed the plugs and i have had it for a year and a half and put 12,000 miles on it. It has 140,000 on it. The stock plugs are said to be motorcraft double platinum they are like $5 each and the g3's are $6 each and i have seen them advertising them on horsepower tv saying they where the best thing sense running water.
Old August 12th, 2009, 11:47 PM   #4
86ttops's Avatar
n/a
By the way i checked my mpg this weekend and was getting 22mpg with the air on in 90+ deg weather on the high way does this sound right?
Old August 12th, 2009, 11:57 PM   #5
Bearer of Bad News
Fluffy The Rhino's Avatar
I has mustang and legacy.
Slower than my Ruger.
Fluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to behold
Might as well replace the O2 sensors.
~MOD NUTSWINGER~
My Tongue Soothes Razorburn
STOPSAYINGFAIL.COM
EVERY FART IS A GAMBLE
Just Think Of Me As A White Blood Cell.
Old August 13th, 2009, 12:08 AM   #6
86ttops's Avatar
n/a
I am not going to replace all of them right now just cant afford it. I bought a bosh o2 sensor to replace the bad one.
Old August 13th, 2009, 01:03 AM   #7
when you replace on in a week the other one will go bad. it happened to me
Old August 13th, 2009, 01:07 AM   #8
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
zinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud of
That is quite simply about as ignorant as it gets.
I have been running 1 Bosch O2 Sensor and 3 Stock O2 Sensors for over 4 months now and the only issue I had was the O2 Sensor I originally bought was bad out of the box.
Mods in garage. New mods, new track times soon.
Old August 13th, 2009, 01:10 AM   #9
86ttops's Avatar
n/a
Kinda what i thought sounds to me like he may have replaced the wrong one? Which is why i am trying to figure out where bank 1 sensor 1 is? I dont have a extra $200 to spend on it at the moment or i would replace them all.
Old August 13th, 2009, 01:17 AM   #10
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
Bank 1 is cylinder side 1. Passenger side on our cars.
What was the Code exactly and I can tell you all you need to know?
Old August 13th, 2009, 01:26 AM   #11
86ttops's Avatar
n/a
Honstly didnt look at the code it has said it before i posted it before and no one awnsered me let me see if i can find it.
Old August 13th, 2009, 01:34 AM   #12
86ttops's Avatar
n/a
This is all i had sorry
switches-lean
bank 1 sensor 1
Old August 13th, 2009, 01:41 AM   #13
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
I'm gonna say front, passenger side sensor.
As for a tune up, get NGK TR55 plugs gaped at .054, fuel filter, oil change, clean your intake, change coolant, change transmission fluid, change differential oil, flush brakes, replcae PCV
Old August 13th, 2009, 02:02 AM   #14
86ttops's Avatar
n/a
You must have missed the part where i said i was going to not spend $200 lol thanks for your help i will replace this weekend and report back .
Old August 13th, 2009, 02:07 AM   #15
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
The spark plugs are like $17 for all eight. Fuel filter is like $7, coolant is like $15, Transmission is about $25, oil is $35. You can pick and choose.
Old August 13th, 2009, 10:58 AM   #16
hey zinc bet you think its cool knowing everything huh. i was saying that because i did replace my front left 02 sensor. code went away and what do you know a week later the other one was reading bad. just like my mechanic said and just like the ford place said. yea i have bosh on mine too but when i go forced induction my tuner said to go back to the oem ones from ford. oh yea you probably know how to tune cars too. is that right or wrong
Old August 13th, 2009, 12:56 PM   #17
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
Don't be immature dude. It was an ignorant statement. THe only reason it would do that is probably due to you putting it on the wrong side. I can't help that I actually learned how to do it right on my car. I never cailmed to know everything either.
Old August 13th, 2009, 04:06 PM   #18
if you say bro. whatever you say
Old August 13th, 2009, 04:11 PM   #19
Proud American
MustangMatt96GT's Avatar
an oxygen sensor is an oxygen sensor... it will read correctly no matter what if its a good oxygen sensor...
the brand is the only thing that is going to determine how long it "lives"
and by replacing one oxygen sensor, it does not mean the other side is going to go... could have just been yours went at the same time... but hell on my moms expedition, i have put three drivers side up stream sensors on, and guess what none of the rest went bad... Too bad the ones i put in(off on of the mustang exhausts I have) were bad after only a few thousand miles...
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old August 13th, 2009, 04:15 PM   #20
lol yea. well mine where 10 years old too so that might be the reason and plus where i had long tubes installed they spliced them and exstended them. so i just bought new ones. all i know is my tuner said once i go forced induction to go get ford oem ones. he said all the other ones are junk
Threads Similar to: Need oxygen sensor help
Oxygen Sensor bigredpaintbllr 5.0 Mustangs 10 July 19th, 2009 02:16 AM
Oxygen Sensor Locations saltydog_NM 5.0 Mustangs 2 June 6th, 2009 07:50 PM
removing oxygen sensor 6banger96 V6 Mustangs 6 June 16th, 2008 10:45 PM
Only Have One Oxygen Sensor Hooked Up? black88 5.0 Mustangs 9 November 20th, 2007 04:46 PM
Oxygen sensor question MnrlGry01gt 99-04 3 June 2nd, 2007 02:17 PM
