315/30/18
Old August 16th, 2009, 12:12 PM   #1
Junk96GT is on a distinguished road
I'm about to bite the bullet and get the 315s for my 18x10 Saleen rear wheels but I want to know if I can get these to fit. The tail pipes are closer to rubbing than my quad shocks are. Right now I run 285/30/18. No rubbing other than it looks like during corners or something my driver side tail pipe rubs the tire a very little bit. But I'm sure I can work things out with that. I may need to run wheel spacers but I don't mind so long as the 1.25" wheel spacer works and doesn't make my car look dumb on an 18x10.
Opinions appreciated!
Old August 16th, 2009, 12:32 PM   #2
IBEATU
stanglifemike's Avatar
06 GT, 98 GT, & 93 Notch
stanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nice
I have 18x10 rear wheels with 305/35/18 and I run a 1" wheel spacer. I believe they will fit without them but I really like the look with them and this way I dont have rubbing in cornering as you had mentioned. I have the Nitto 555R's. 305's look sexy on the back on sn95's!! DO IT
98 GT: some stuff
06 GT: more stuff
93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper
Paxton/Vortech Crew Member #3
FRPP's #1 Dealer
Injected Engineering
BMR Suspension
Old August 16th, 2009, 12:37 PM   #3
IBEATU
Oh yea, make sure that you buy hub-centric wheel spacers and you'll be fine. I have had zero issues with mine coming loose or anything. Bought mine on Ebay
98 GT: some stuff
06 GT: more stuff
FRPP's #1 Dealer
BMR Suspension
Old August 16th, 2009, 12:41 PM   #4
IBEATU
These are the ones I bought and the seller that I bought them from. Great customer service, you can call them with any questions that you have.
WHEELS SPACERS ADAPTERS Ford Mustang Hub Centric GT 1":eBay Motors (item 110423150313 end time Aug-17-09 13:09:11 PDT)
98 GT: some stuff
06 GT: more stuff
FRPP's #1 Dealer
BMR Suspension
Old August 16th, 2009, 06:04 PM   #5
96GAredGT is on a distinguished road
I work in the tire industry and would reccomend doing 305's or even 295's( which are what I currently have on my Saleen wheels). Anything bigger then the 305 you would have to tub out the rear or it would rub on corners and bumps
Old August 16th, 2009, 09:06 PM   #6
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
I don't see any rubbing issues that cannot be dealt with by some slight bending of exhaust hangers
However, I don't recommend you go 315's on your 10" wheels or run a 1" spacer either. I think you are VERY likely to rub on the fender with a 1" spacer and not fond of the "linked" type anyway. I think they can come loose and unable to tell without removing the wheels to check. If you want to move the wheels outward, I would recommend a 1/2" spacer with longer/stronger studs.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old August 16th, 2009, 11:08 PM   #7
BlackSunshine
Guest
Posts: n/a
I thought 315's would fit without rubbing? Maybe it is 315/35/17 that won't rub I guess there is big difference between 17's and 18's...
Old August 16th, 2009, 11:14 PM   #8
Stang8Grand's Avatar
13.85 on stock garbage tires
Stang8Grand is on a distinguished road
Send a message via AIM to Stang8Grand Send a message via MSN to Stang8Grand
I run a 285 35 18 on the rear and with 1" spacers if go over the right bump or rut i do get some rubbing on my fenders in the rear. If you do get 1" spacers (which has given me no issues other then the fender rubbing) i would recommend getting your fenders rolled, i am looking into doing it very soon.
Mods in garage. http://www.moddedmustangs.com/forums...-member-11489/
Old August 17th, 2009, 08:51 PM   #9
Yeah 315 35 17's won't rub but 18's are extremly close. 305's are the biggest I would personally go. Spacer would help but you will have the potential to rub the fenders. Personally I have the 295's and have never had any rubbing problems and I am not using any spacer.
Old August 17th, 2009, 11:19 PM   #10
Abyssinian of AX
'02 Saleen
19.34@42.259
315/35/17" = 25.6" diameter
315/30/18" = 25.6" diameter
... as you were
Old August 17th, 2009, 11:26 PM   #11
Anasty97Cobra's Avatar
1997 mustang cobra
12.7@114.3
Anasty97Cobra is on a distinguished road
... as you were
you just need a little faith...
MM COBRA CLUB MEMBER #44
Old October 8th, 2009, 02:17 PM   #12
nmcgrawj is on a distinguished road
... as you were
actuallly.....
17's
315*.35 = 110.25
110.25/25.4 = 4.3405
4.3405 * 2 = 8.681
8.681 + 17 = 25.681
18's
315*.30 = 94.5
94.5/25.4 = 3.7204
3.7204*2 = 7.4409
7.4409+18 = 25.44
So 18's are actually shorter than 17s by 1/4 inch
Threads Similar to: 315/30/18
315/35/17 njstang 99-04 27 April 18th, 2009 06:07 PM
315-30-17 luis 99-04 10 January 23rd, 2009 05:35 PM
315 17 or 295 18 renemercado 99-04 23 November 1st, 2007 12:25 PM
315/35-17 tires? UTGT 99-04 10 August 22nd, 2007 09:51 PM
