throw out bearing
Old August 16th, 2009, 11:34 PM   #1
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
throw out bearing
so i've been through this problem once before.. (dec 07) when i bought the car, it needed a throwout.. so we put in a spec clutch and spec tob.. well after the new engine was in there, the TOB squeals ALWAYS unless there is a little pressure on the clutch.. if i barely stick my foot on it, it stops..
I'm going to try putting a weight of some sort on the pedal and maybe it will keep it from squealing..
also, is there anything i can try to spray on it (through the cable cover) that will help it out? ill put a clutch in it probably when i got the money..
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
Old August 17th, 2009, 01:32 AM   #2
330CubeGt's Avatar
1994 Mustang 5.0
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
Spec Sucks,My Spec TOB Broke in half with in 5 miles of use,And I don't know where you got this idea of hanging a weight on the clutch pedal but thats the worse idea i have heard,Its just gona Wipe the TOB out faster.But what ever makes you happy
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old August 17th, 2009, 06:42 AM   #3
JiMi_DRiX's Avatar
1 lowwww mileage 97 GT
slow @ 88mph, doc.
JiMi_DRiX is on a distinguished road
Send a message via AIM to JiMi_DRiX
I dont know what you have in your Mustang, but whats a good replacement TOB and Clutch for a stock GT? Just the ol FOMOCO parts? or is there something good aftermarket that better worth the money?
Old August 17th, 2009, 08:11 AM   #4
4.6L Coupe' 5spd
2002 BLK GT will become famous soon enough
Send a message via AIM to 2002 BLK GT
Its sounds like it needs to be adjusted I would buy an adjuster first you will love it, you can get this MUSTANG 92 94 95 96 97 98 CLUTCH QUADRANT FIREWALL ADJ:eBay Motors (item 290340618622 end time Aug-26-09 14:15:44 PDT)
and theres a vid on AM on how to install it but before If I were you I would watch the vid first then inspect the cable and buy the whole kit its still cheaper than 100 from AM......
Old August 17th, 2009, 08:13 AM   #5
4.6L Coupe' 5spd
The oem, or a reputable stage 1 clutch, theres different opinions on this but I will go with a centerforce ..... also some people recommend the oem tob.
Old August 17th, 2009, 10:08 PM   #6
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
That's what im wondering.. because when the pedal is touched, the squeal goes away, but if there's no pressure on it, it squeals.
Cammed 2v
Old August 17th, 2009, 10:08 PM   #7
Moderator
TOB is Throw Out Bearing
Old August 19th, 2009, 08:19 PM   #8
MikeD05GT's Avatar
2005 Mustang GT
MikeD05GT will become famous soon enoughMikeD05GT will become famous soon enough
Send a message via AIM to MikeD05GT
i put a steeda adjustable cable and a quadrant in my car... fixed the same problem...
oh and @ putting weight on pedal
Old August 19th, 2009, 08:22 PM   #9
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
dont ever use aftermarket TOB (TOB= Throw Out Bearing) the best one that i found to be is the FRPP TOB (TOB = Throw out bearing)
BUILD 2 IN PROGRESS
Old August 19th, 2009, 08:56 PM   #10
3rd Place '11 ROTY
Jazzer The Cat's Avatar
'02 GR-40/SLA Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
What is a TOB?
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Jazzer The Ego HD Vids
Tire and Wheel Fitment Guide | C/A Livernois beast build
Man those are some fantastic milk transporting devices... "
Old August 20th, 2009, 12:17 AM   #11
330CubeGt's Avatar
1994 Mustang 5.0
1996 Mustang V6
iTrader: 14 reviews
Originally Posted by Jazzer The Cat View Post
What is a TOB?
BOT Backwards
Old August 20th, 2009, 09:57 AM   #12
3rd Place '11 ROTY
19.34@42.259
hmmmm.... like this?
Saweeet
Old August 23rd, 2009, 06:27 AM   #13
X3FBrian's Avatar
X3FBrian is on a distinguished road
Buy a 30$ adjustable cable, don't mess with a firewall adjuster. Tighten the cable up to put a touch of pressure on the cable. Or do it the right way and replace the TOB
Old August 23rd, 2009, 11:05 AM   #14
3rd Place '11 ROTY
19.34@42.259
It is best NOT to have the bearing running all the time.
I realize that Ford designed the TOB to be continuously running, but it will fail sooner that way. I am guessing that the bearing is VERY close to the pressure plate, but not in full contact. The sqealing is likely just a single spline rubbing on the bearing in a particular spot upon each revolution.
You need
Old August 23rd, 2009, 11:10 AM   #15
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
for Jazzers video
BUILD 2 IN PROGRESS
Threads Similar to: throw out bearing
Throw out bearing? DickH 99-04 3 August 30th, 2008 12:45 AM
Throw Out Bearing Lefty 4V / SVT 0 June 29th, 2008 07:10 PM
throw out bearing 40thmustanggt 99-04 2 August 8th, 2007 07:45 PM
Throw Out Bearing KMast14 V6 Mustangs 17 August 6th, 2007 07:43 PM
throw out bearing already???? 40thmustanggt 99-04 12 July 9th, 2007 10:26 PM
