Discussing Car Is Cutting Out! Help! in the 96-98 Forum. I need help with my car. The check engine light never came on and every ...
Old March 12th, 2006, 03:17 AM   #1
I need help with my car. The check engine light never came on and every time i turn on any type of air conditioning or heater whether it defrost or vent, my car will cut out. It doesn't do it while i'm actually driving but if i take it out of gear and coast it nearly kills itself. Letting it idle i can hear it drop rpm's really fast but then it catches itself before it dies. It is a 1998 mustang gt. 4.6 L. five speed.
Old March 12th, 2006, 08:59 AM   #2
check your iac valve. sometimes carbon builds up, and starts catching the valve portion ... sometimes it gets caught closed. when coasting, your throttle is closed, so the iac kicks in to keep the engine running. and if it gets caught up closed, your engine will shutoff.
Old March 12th, 2006, 09:43 PM   #3
definetly sounds like an iac problem. time to replace it. sometimes you can clean them, but they usually stick again in no time.
88 Mustang Coupe
www.rickscarcare.net
http://img146.imageshack.us/img146/2158/ricksadql2.jpg
Old March 12th, 2006, 10:30 PM   #4
Grandpa
that damn iac... everytime i turn around, someones iac is shot... hey tim(white99stang), how is your iac buddy
Old March 13th, 2006, 08:54 AM   #5
99mustang232's Avatar
1999 Ford Mustang V6
this is why i have a spare sitting in my garage, not to mention it helps troubleshooting it is a worth while investment.
Old September 11th, 2006, 07:31 PM   #6
my car does the same thing, did the IAC fix ur prob? or i need to fix mine
Old September 13th, 2006, 06:21 AM   #7
I REPLACED MINE AND FOR ABOUNT A WEEK IT WAS RUNNING NICE AND SWEET BUT NOW ITS THE SAME THING OVER AND OVER ? ;-/
Old September 13th, 2006, 07:25 AM   #8
Black Mamba
C MY 4D's Avatar
2003 Cobra
11.14@124.36
vacuum leak
Black Cobra Club Member
The black mamba is reputed to be the fastest moving snake in the world.....
Old September 13th, 2006, 01:43 PM   #9
SP00LIN V6
2000 Mustang V6
unknown @390
Re: Car Is Cutting Out! Help!
thats sounds pretty damm dangerous
437rwhp and 402rwtq through a V6 on a stock bottom end
Old September 13th, 2006, 04:39 PM   #10
Mines doing the same thing, and I have a 98 mustang GT too, 4.6 5 speed, I replaced MAF, New Plugs, new o2 sensors, new TPS, cleaned my IAC, and previous owner put a new intake manifold, old one was cracked, so I have no clue wat I should try next
Old September 14th, 2006, 09:17 PM   #11
I would try looking for a vacuum leak in the heater control if it has one, I could look at my 97 cobra later,also check and see if the battery power drops when the problem occors,something in the charging system may be messed up. the air conditioner is turned on in defrost but not in vent so you might be able to rule out the compresser, my 97 has the original battery in it and it couldnt start my boat but it starts my car just fine for now and turning on my ac does not kill my engine but it does make my supercharger sound a little sick. use a digital vom and check charging system.
Threads Similar to: Car Is Cutting Out! Help!
Cutting Out Illuminator 5.0 Mustangs 2 November 13th, 2007 11:45 AM
car cutting out..please help 89LX347 5.0 Mustangs 12 June 4th, 2007 07:53 PM
car cutting off raceruler03 99-04 4 April 14th, 2007 12:40 PM
cutting my antenna? TheTechnical99 Electronics 10 January 3rd, 2007 12:04 AM
Car is cutting out top end!! boosted89 5.0 Mustangs 7 November 19th, 2006 08:15 PM
