wont start still
ok guys im running out of options here besides takeing it to a shop and haveing them figure it out...i have cleaned the maf ...changed plugs and fuel filter i have spark....and fuel...the car was running went inside for about 5 mins came out and it had shut off and hasnt started sence....im not sure what else to check i have good fuel pressure...the car has 80k on it is it possible that it has jumped timeing? i really dont know what else to check
does the car try to crank when you turn the key.
97 Mustang GT, MAC CAI, Underdrive Pulleys, Flowmaster Exhaust, BBK Offroad H-Pipe, 3:73 Gear, Autologic Chip, B&M Short Throw Shifter, Centerforce Clutch, Msd, Eibach Sportline Springs |
cranks just wont catch
since you do have fuel and spark, then you could possibly have an injector problem. And since it is unlikely all eight injectors went bad at the same time, check for power going to the injectors. have you checked for fuel around the injectors,?try bleedin the valve on the fuel rail to see if you have fuel there. also check the fuel pump cutoff switch. it may need to be reset.
Threads Similar to: wont start still
| Wont Start | caintcatchmyGT | 96-98 | 3 | September 10th, 2007 11:02 PM |
| wont start | snailstang | 96-98 | 24 | August 30th, 2007 09:46 AM |
| need help...car wont start | orlyr21 | V6 Mustangs | 8 | January 13th, 2007 08:17 PM |
| wont start?? | shadowgames81 | 5.0 Mustangs | 10 | January 7th, 2007 09:10 PM |
| 91-92 5.0 gt wont start | sturcotte3 | 5.0 Mustangs | 0 | January 1st, 2007 05:40 PM |
