will it hurt??
Old February 14th, 2007, 10:34 PM   #1
AnglicoGT98 is on a distinguished road
Send a message via AIM to AnglicoGT98
will it hurt??
i have seen alot of stuff about EGR deletion...is it a good or bad idea?? i mean, it sounds like a pointless part and all it does is cause problems..do you just get a plate to put over it and be done with it??
98gt, mac o/r h pipe, mac cat back, diablo tuner, k2 CAI, c&l 85mm plenum, pro products 85mmTB
Old February 14th, 2007, 11:56 PM   #2
well i did some research and i'm gonna try it... IF ANYONE KNOWS WHERE I CAN GET THE BLACK OFF PLATE AND THE MIL SENSOR PLEASE LET ME KNOW!!!!
Old February 15th, 2007, 08:37 AM   #3
Casper98GT's Avatar
I bought the plate and was going to install when i did my pi swap. But i ended up not doing it. What you do is install the block off plate, and then get off the egr tube from the exhaust and then put a cap over the manifold. what it does it keeps youre intake clean and doesnt carbon up. you can do it if you want, i chose not to because was more work than worth. haha
91 LX, 5spd.
Ex:Toyota/Ford tech
Old February 15th, 2007, 03:26 PM   #4
what do you do about that sensor?? also what knd of cap do you use?? and if you didnt use your plate..wanna sell it??
p.s.-nice work on that manifold install
Old February 16th, 2007, 09:15 AM   #5
Casper98GT's Avatar
Yeah i will GIVE it to you. The check engine light would stay on, but you may be able to get a tuner to turn egr off. Not sure. Anyways, As for the cap i was going to weld a metal cap over my exhaust. If you want the easy way out, just put the EGR block off between the EGR and the intake plenum, so that its blocked off and you wont have a leak.
The reason why you remove the pipe and everything else is because you want the "show" look. You can remove the EGR gasket and put the block off and it would work the same.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old February 17th, 2007, 10:32 AM   #6
hey i pm'ed you about setting up getting me that plate...let me know
Threads Similar to: will it hurt??
Will this hurt? 06RedfireGT The Clubhouse 3 November 9th, 2007 12:01 AM
will this help just a little or will it hurt??? droppedbass87 96-98 8 September 23rd, 2007 09:12 PM
will this hurt Blackblurr_00GT Modular Mustangs 7 August 17th, 2007 12:07 AM
hey soo how much will this hurt me? superman5.0 5.0 Mustangs 5 August 14th, 2007 01:50 AM
This had to hurt! 99MarkIII Multimedia 1 October 22nd, 2005 01:27 AM
