#21 | |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
you can have the crank cryo treated for strength as example of treating it for strength. balancing is a process of the whole rotating assembly. |
#22 |
1998 Mustang Base Model
That sux, but it wasnt the crank that was the blow out for you. Either way, doesnt look like there was any usable parts left in the engine. I just bought new c heads for my set up and i want to make sure nothing happens to them. Blocks are expendible, i can pick up alum. v blocks in the junk yard all day for less then $100. we've got tons of mark 8s and it only takes about an hour to pull an engine out of one(junk yard style). The heads and rotating assembly are what cost the most.
In the end i problay will go with a forged crank, but its still up in the air. I dont see any need for more then 600hp out of a street car. I dont plan on taking it to the track, i just want a really fast street car. I dont plan on using it as a daily driver either. After i build the engine and put it in, its going to the dyno shop to be tuned and then well see what happens from there. |
#23 |
mm's nitrous mod
2000 mustang gt
nope, hurt piston and rod. where you located? i am looking to buy up some blocks as well.
#24 |
im in maryland.
#25 |
Hooo Ha Ha
Just want to point out that oddly there alot of members on here from maryland. I also am from MD
BTW go with the forged crank. When the motor blows you will be kicking yourself for skipping it. Do it right the first time so you can beat the crap out of it later without any worries. You also will save yourself from that little voice in the back of your head the first time you let it loose saying "Shit i hope it dosnt blow".
![]() 374rwhp 456rwtq @ 8psi |
#26 |
mm's nitrous mod
2000 mustang gt
do it right the first time? whats wrong with using a 650hp rated crank for a 500hp set up??? doing something like that would be a waste of money that could be better used else where. its just like the idiots that go out and get teksid blocks just so its capable of holding 3 times the power they are going to push.
#27 | |
1994 Mustang 5.0
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
I Agree...For Ex: After i see what condition this 5.4 i have is in i might have to get the crank turned but i will most likely keep it stock and get some half decent rods/pistons and arp hardware and go for 600hp if the Eaton will allow me to lol. In my case i don't have the extra cash but instead of a forged crank i can through the money at my tranny. and i would be much more worried about that letting loose then the crank. Just my 2 cents.
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
#28 |
1994 Mustang 5.0
1996 Mustang V6
IDK about you but anytime i go out i try to break something so to speak.And if it does it gives you reason to tear it down and build it stronger.
#29 | |
Now my project is at a cross roads and its time for rebuilding. In the end i do think i will go with a forged crank because knowing me, once i get to my goal of 600rwhp i will want more. |
Threads Similar to: How much hp from stock cast crank?
| TW fast as cast heads with track heat manifold on stock 5.0 | cornellm5 | 5.0 Mustangs | 2 | August 19th, 2009 11:18 PM |
| what is the diameter of a stock 98 cobra crank pulley??? | cobra_strike | 4V / SVT | 2 | July 20th, 2009 11:17 PM |
| stock crank horse power rating? | Boostang | 99-04 | 46 | May 27th, 2009 07:38 PM |
| 2v stock crank power??? | lilmarc1988 | 99-04 | 15 | May 10th, 2008 01:10 PM |
| stock crank strength? | MyGT | 99-04 | 5 | March 2nd, 2008 11:14 PM |
